[GRASS-user] Using RStudio in a GRASS GIS session
sibylle.stoeckli at gmx.ch
Fri Apr 19 06:09:01 PDT 2024
Dear community
Thank you very much for all your input.
Unfortunately I got always the same error
The command "rstudio" is either misspelled or
could not be found.
The command "GRASS" is either misspelled or
could not be found.
Find here some info about the operating system:
GRASS version: 8.3.2
Code revision: 695385bb79
Build date: 2024-03-07
Build platform: x86_64-w64-mingw32
GDAL: 3.8.4
PROJ: 9.3.1
GEOS: 3.12.1
SQLite: 3.41.1
Python: 3.9.18
wxPython: 4.2.1
Platform: Windows-10-10.0.19045-SP0 .
Kind regards
Sibylle
From: grass-user <grass-user-bounces at lists.osgeo.org> On Behalf Of Bernardo Santos via grass-user
Sent: Friday, April 19, 2024 11:09 AM
To: Veronica Andreo <veroandreo at gmail.com>; Veronica Andreo via grass-user <grass-user at lists.osgeo.org>; Micha Silver <tsvibar at gmail.com>; Paulo van Breugel <p.vanbreugel at gmail.com>
Subject: Re: [GRASS-user] Using RStudio in a GRASS GIS session
Hi Sybille,
I have never tried opening Rstudio from the GRASS terminal, but I know that it is possible to open R. So as others have mentioned, you could try to first open R (from the GRASS terminal) and within it try `library(rgrass)` (or `install.packages("rgrass")` if it was not installed yet).
But I also know there are some issues when working with both R/RStudio and GRASS in Windows, also related to how GRASS was installed and if R/Rstudio are recognized in the PATH variables. Please take a look at these notes here and check if any of that helps you: Connecting to GRASS from R in Windows · Issue #10 · NINAnor/oneimpact (github.com) <https://github.com/NINAnor/oneimpact/issues/10>
Best
Bernardo
Em sexta-feira, 19 de abril de 2024 às 08:13:40 GMT+2, Paulo van Breugel via grass-user <grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org> > escreveu:
>From the message that library is not found, I wonder, did you type
GRASS> rstudio & library(grass)
all on the command line?
Just to be sure, you should ope Grass gis. And in the grass gis command line, type
rstudio &
Next, after RStudio opens, you type the following in RStudio
library(grass)
On April 18, 2024 7:56:03 PM GMT+02:00, Veronica Andreo via grass-user <grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org> > wrote:
Hello Sibylle,
Perhaps you can tell us some details about your operative system, which GRASS installer you are using (i.e., standalone or OSGeo4W), how did you start GRASS, if R and RStudio are installed.
>From your email, I do not understand why GRASS is not recognized as a command, as it seems you **are** already within a GRASS session on the terminal? (i.e. you have a GRASS prompt there `GRASS>`).
Vero
El jue, 18 abr 2024 a las 12:06, Micha Silver via grass-user (<grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org> >) escribió:
Silly question, do you have the 'rgrass' library installed?
i.e. can you do `library(rgrass)` at the R command prompt (without rstudio)?
On 17/04/2024 21:34, sibylle via grass-user wrote:
Dear community
To use RStudio in a GRASS GIS session I used the command line
GRASS> rstudio &
library(rgrass)
(see https://grasswiki.osgeo.org/wiki/R_statistics/rgrass)
Unfortunately I was not able to solve the error message:
- The command "GRASS" is either misspelled or
could not be found.
- The command "library" is either misspelled or
could not be found.
Kind regards
Sibylle
(Wed Apr 17 20:25:17 2024)
GRASS> rstudio &
Der Befehl "GRASS" ist entweder falsch geschrieben oder
konnte nicht gefunden werden.
(Wed Apr 17 20:25:17 2024) Command ended with non-zero return code 1 (0 sec)
(Wed Apr 17 20:25:29 2024)
library(rgrass)
Der Befehl "library" ist entweder falsch geschrieben oder
(Wed Apr 17 20:25:29 2024) Command ended with non-zero return code 1 (0 sec)
grass-user mailing list
https://lists.osgeo.org/mailman/listinfo/grass-user
Micha Silver
Ben Gurion Univ.
Sde Boker, Remote Sensing Lab
cell: +972-523-665918
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20240419/82084a8b/attachment-0001.htm>
