[GRASS-user] Using RStudio in a GRASS GIS session
sibylle.stoeckli at gmx.ch
Sat Apr 20 04:10:25 PDT 2024
Dear Roger
Dear community
May aim is to use RStudio in a GRASS GIS session, to visualize raster and
vector data: e.g. a boxplot of a species raster file or boxplot of a species
raster file differentiated for different regions (vector file).
Similar in
https://ecodiv.earth/post/drawing-boxplots-of-raster-values/
Because of my name with ö I changed the location to C:/GrassGIS: this
seems to be the solution for the error when staring GRASS. No warming
anymore.
Using the command line, I was able to produce a boxplot.
I am more comfortable in R, so I tried starting R inside the GRASS console
(as suggested for windows) following the code here:
https://rsbivand.github.io/rgrass/articles/use.html
However, I am still struggling around with the error
The command "library" is either misspelled or
could not be found.
library(rgrass)
Der Befehl "library" ist entweder falsch geschrieben oder
konnte nicht gefunden werden.
(Sat Apr 20 12:57:24 2024) Command ended with non-zero return code 1 (0 sec)
Kind regards
Sibylle
Sent: Saturday, April 20, 2024 8:09 AM
To: sibylle.stoeckli at gmx.ch
Cc: grass-user at lists.osgeo.org
Subject: Re: [GRASS-user] Using RStudio in a GRASS GIS session
First tell us exactly what you do. Do you start GRASS first (how was GRASS
installed, which version?), then what? The first message suggests a failed
GRASS installation. Can you use GRASS at all? Try to run any regular example
on the data in your location in GRASS to check that GRASS works before
anything else.
Roger Bivand
Emeritus Professor
Department of Economics
Norwegian School of Economics, Bergen, Norway
_____
Fra: sibylle.stoeckli at gmx.ch <mailto:sibylle.stoeckli at gmx.ch>
<sibylle.stoeckli at gmx.ch <mailto:sibylle.stoeckli at gmx.ch> >
Sendt: fredag, april 19, 2024 5:56:04 p.m.
Til: Roger Bivand <Roger.Bivand at nhh.no <mailto:Roger.Bivand at nhh.no> >
Kopi: grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
<grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org> >
Emne: RE: [GRASS-user] Using RStudio in a GRASS GIS session
Dear community
Dear Roger
I suppose it is my name
Here the output from the console:
C:\Users\Sibylle Stöckli>
ERROR: Unable to read WIND file: not enough values to unpack (expected 2,
got 1)
library(rgrass)
Kind regards
Sibylle
-----Original Message-----
From: Roger Bivand <Roger.Bivand at nhh.no <mailto:Roger.Bivand at nhh.no> >
Sent: Friday, April 19, 2024 4:31 PM
To: sibylle.stoeckli at gmx.ch <mailto:sibylle.stoeckli at gmx.ch>
Cc: grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
Please see:
https://eur02.safelinks.protection.outlook.com/?url=https%3A%2F%2Frsbivand.g
ithub.io%2Frgrass%2Farticles%2Fuse.html
<https://rsbivand.github.io/rgrass/articles/use.html>
&data=05%7C02%7CRoger.Bivand%40nhh.no%7C04d6d2c547b14550ec5f08dc608936de%7C3
3a15b2f849941998d56f20b5aa91af2%7C0%7C0%7C638491389645818206%7CUnknown%7CTWF
pbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%
7C0%7C%7C%7C&sdata=3fLYSzCE3uRNBetqb69RxZz%2FzLiv%2F1LuBFkdb%2B19nsA%3D&rese
rved=0.
3a15b2f849941998d56f20b5aa91af2%7C0%7C0%7C638491389645826443%7CUnknown%7CTWF
7C0%7C%7C%7C&sdata=zM%2Fia4%2BGNTgKd%2Bjxo3HVJnDgt02JrI9CSyx%2F1AtwK%2FU%3D&
reserved=0
Do you have a GRASS location and wish to use R on the data in that location?
Then start GRASS first and start rstudio from inside GRASS.
The error messages suggest that something is missing in your installation.
Is your query related to
https://eur02.safelinks.protection.outlook.com/?url=https%3A%2F%2Fstat.ethz.
ch%2Fpipermail%2Fr-help%2F2024-April%2F479232.html
<https://stat.ethz.ch/pipermail/r-help/2024-April/479232.html>
3a15b2f849941998d56f20b5aa91af2%7C0%7C0%7C638491389645832105%7CUnknown%7CTWF
7C0%7C%7C%7C&sdata=i1bTT5y7lmJcG1MtEniurDJsEYbK63t0UB%2BSagiLmMM%3D&reserved
=0 ?
Roger Bivand
Emeritus Professor
Postboks 3490 Ytre Sandviken, 5045 Bergen, Norway Roger.Bivand at nhh.no
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20240420/c81d83ee/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20240420/c81d83ee/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20240420/c81d83ee/attachment-0003.png>
