[GRASS-user] Boxplots based on raster data in GRASS GIS
sibylle.stoeckli at gmx.ch
Wed Apr 24 01:05:40 PDT 2024
Dear community
After installing GRASS GIS 8.3.2 (windows), setting all the correct paths to
run rstudio within a GRASS GIS session (many thanks to the community!) and
installing the addon r.boxplot, I was able to run part of the code in
example 1
https://ecodiv.earth/post/drawing-boxplots-of-raster-values/
Great tool, I was able to produce the boxplot using GUI or the command line.
Example 1
# Import the required library
library(rgrass)
# Set the region and MASK
execGRASS("g.region", flags="a", vector="TALregion",
raster="LAI300_20140920")
execGRASS("r.mask", vector="TALregion")
However, I received the error message, that r.boxplot is not found. I tried
to install r.boxplot via r package, however, there is no r.boxplot r
package. Searching the GRASS GIS help, I am not aware of an additional code
section for r.boxplot?
Kind regards
Sibylle
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20240424/58669d43/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20240424/58669d43/attachment-0001.png>
