[GRASS-user] Is ther a quick way to install grass8.3.2 in Ubuntu Jammy?
    Jürgen E. Fischer
    jef at norbit.de
    Wed Aug  7 02:36:03 PDT 2024
Hi Luís,
On Tue, 06. Aug 2024 at 07:11:55 +0000, Luís Moreira de Sousa via grass-user wrote:
> that version of QGis is not available from Ubuntu-GIS, therefore you should
> not expect packages provided by that PPA to link correctly with QGis. Either
> you install the QGis-GRASS bridge from the same source you installed QGis, or
> you install everything from Ubuntu-GIS. Anything else will inevitably to lead
> to a messy package set-up at some point.
QGIS has packages based on ubuntugis (also latest not only ltr).   But
https://www.qgis.org/resources/installation-guide/#note-4 applies.
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden            https://www.norbit.de
QGIS release manager (PSC)  Germany                 IRC: jef on Libera|OFTC
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20240807/368fcadc/attachment.sig>
