[GRASS-user] i.sentinel add-on incomplete in WinGrass 8.4?
Veronica Andreo veroandreo at gmail.com
Tue Aug 27 12:18:35 PDT 2024
Hi Vishal,
In any case, please notice that i.sentinel.download received significant
changes lately given that sentinelsat was no longer maintained and Sentinel
data was moved from the Copernicus Open Access Hub to the Copernicus Data
Space Ecosystem. i.sentinel.download now depends on i.eodag extension and
EODAG library [1,2]. So, since i.sentinel.coverage uses i.sentinel.download
as I am realizing now, it will probably need to be reviewed at least.
I'm putting Hamed in cc here, as he was the GSoC contributor working on the
updates.
Best,
Vero
[1] https://grass.osgeo.org/grass84/manuals/addons/i.eodag.html
[2] https://eodag.readthedocs.io/en/stable/
El mar, 27 ago 2024 a las 4:07, Markus Neteler via grass-user (<
grass-user at lists.osgeo.org>) escribió:
> Hi Vishal,
> (cc Martin who maintains the wingrass server)
> Good catch.
> On Tue, Aug 27, 2024 at 4:10 AM Vishal Mehta via grass-user
> <grass-user at lists.osgeo.org> wrote:
> > Hi,
> > I wanted to try out the sentinel toolset, trying to follow :
> > https://training.gismentors.eu/grass-gis-workshop-jena/units/20.html
> > However, the i.sentinel extension seems to be missing
> i.sentinel.coverage:
> > https://wingrass.fsv.cvut.cz/grass84/addons/grass-8.4.0/
> > Any idea if that can be added?
> There seems to be some issue on the wingrass server:
> --> Windows log files
> Basically all jobs fail with:
> Traceback (most recent call last):
>   File "C:\Users\landamar\grass_packager\grass84\addons\db.join\scripts\
> db.join.py",
> line 64, in <module>
>     import grass.script as grass
> ModuleNotFoundError: No module named 'grass'
> Needs to be investigated on the server (I don't have access) by Martin.
> Best
> Markus
> Markus Neteler, PhD
> https://www.mundialis.de - company
> https://grass.osgeo.org - FOSS
> https://neteler.org - freelancing & blog
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
Dra. Verónica Andreo
Investigadora Adjunta de CONICET
Instituto Gulich (CONAE - UNC)
Centro Espacial Teófilo Tabanera (CETT)
Falda del Cañete - Córdoba, Argentina
+54 3547 400000 int. 1153
https://veroandreo.gitlab.io/
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20240827/366199e1/attachment.htm>
