[GRASS-user] i.sentinel add-on incomplete in WinGrass 8.4?
Veronica Andreo
veroandreo at gmail.com
Wed Aug 28 07:20:32 PDT 2024
Hi Vishal,
Yeah, sentinelsat has not received any updates for almost a year now, and
given the move to a different archive, the old i.sentinel.download and
tools using it, wouldn't work anyway. Same happened with
i.landsat.download, whose underlying library is no longer maintained.
We are currently preparing an email with details about the changes. In the
meantime, you can go through Hamed's final report:
https://grasswiki.osgeo.org/wiki/GRASS_GSoC_2024_EODAG_Support#Final_Report
Cheers,
Vero
El mar, 27 ago 2024 a las 17:41, Vishal Mehta (<vishalm1975 at gmail.com>)
escribió:
> Thanks Markus, Veronica,
> Indeed yes, I had wondered about these changes and whether the not-so-old
> work flows would still work!
> Best,
> Vishal
> On Tue, Aug 27, 2024 at 12:18 PM Veronica Andreo <veroandreo at gmail.com>
> wrote:
>> Hi Vishal,
>> In any case, please notice that i.sentinel.download received significant
>> changes lately given that sentinelsat was no longer maintained and Sentinel
>> data was moved from the Copernicus Open Access Hub to the Copernicus Data
>> Space Ecosystem. i.sentinel.download now depends on i.eodag extension and
>> EODAG library [1,2]. So, since i.sentinel.coverage uses i.sentinel.download
>> as I am realizing now, it will probably need to be reviewed at least.
>> I'm putting Hamed in cc here, as he was the GSoC contributor working on
>> the updates.
>> Best,
>> Vero
>> [1] https://grass.osgeo.org/grass84/manuals/addons/i.eodag.html
>> [2] https://eodag.readthedocs.io/en/stable/
>> El mar, 27 ago 2024 a las 4:07, Markus Neteler via grass-user (<
>> grass-user at lists.osgeo.org>) escribió:
>>> Hi Vishal,
>>> (cc Martin who maintains the wingrass server)
>>> Good catch.
>>> On Tue, Aug 27, 2024 at 4:10 AM Vishal Mehta via grass-user
>>> <grass-user at lists.osgeo.org> wrote:
>>> > Hi,
>>> > I wanted to try out the sentinel toolset, trying to follow :
>>> > https://training.gismentors.eu/grass-gis-workshop-jena/units/20.html
>>> > However, the i.sentinel extension seems to be missing
>>> i.sentinel.coverage:
>>> > https://wingrass.fsv.cvut.cz/grass84/addons/grass-8.4.0/
>>> > Any idea if that can be added?
>>> There seems to be some issue on the wingrass server:
>>> --> Windows log files
>>> Basically all jobs fail with:
>>> Traceback (most recent call last):
>>> File "C:\Users\landamar\grass_packager\grass84\addons\db.join\scripts\
>>> db.join.py",
>>> line 64, in <module>
>>> import grass.script as grass
>>> ModuleNotFoundError: No module named 'grass'
>>> Needs to be investigated on the server (I don't have access) by Martin.
>>> Best
>>> Markus
>>> Markus Neteler, PhD
>>> https://www.mundialis.de - company
>>> https://grass.osgeo.org - FOSS
>>> https://neteler.org - freelancing & blog
>>> grass-user mailing list
>>> https://lists.osgeo.org/mailman/listinfo/grass-user
>> Dra. Verónica Andreo
>> Investigadora Adjunta de CONICET
>> Instituto Gulich (CONAE - UNC)
>> Centro Espacial Teófilo Tabanera (CETT)
>> Falda del Cañete - Córdoba, Argentina
>> +54 3547 400000 int. 1153
>> https://veroandreo.gitlab.io/
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20240828/9e417a87/attachment-0001.htm>
