[GRASS-user] Open GRASS at remote grassdata
Stuart Edwards
sedwards at verdantenv.com
Wed May 1 12:44:07 PDT 2024
Thanks for the quick response - that works.....
Stu
On May 1 2024, at 3:02 pm, Anna Petrášová <kratochanna at gmail.com> wrote:
> Yes, this has changed, you can add a new directory from the data catalog:
> https://youtu.be/OCcM1XfxHW8?feature=shared&t=370
> On Wed, May 1, 2024 at 2:45 PM Stuart Edwards via grass-user <grass-user at lists.osgeo.org (mailto:grass-user at lists.osgeo.org)> wrote:
> > Hi -
> > I am trying to open GRASS 8.3 using a grassdata directory located on a personal cloud storage device. GRASS opens using the grassdata last used, and I see no way to navigate to the storage device instead. I tried deactivating the grassdata in my home directory in the hope that it would result in dialogue to navigate to an alternative. But no such luck. I just get a temporary location.
> > It appears that as late as GRASS 7.9, the first window to open provided the opportunity to select a grassdata located elsewhere - that was not the last used or present in home. Has the new GUI changed this, or am I just missing something obvious?
> > Any help much appreciated!
> > Stu
> > grass-user mailing list
> > https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20240501/e1749d45/attachment.htm>
