[GRASS-user] Error when launching GRASS GIS 8.3.2
Markus Neteler
neteler at osgeo.org
Thu May 9 02:53:59 PDT 2024
Hi Filipe,
On Fri, Apr 26, 2024 at 4:13 PM Filipe Dias via grass-user
<grass-user at lists.osgeo.org> wrote:
> Dear All,
> When I try to launch grass 8.3.2 (Pop OS/ Ubuntu 22.04) I get this error. I did a clean installation from ubuntugis unstable. "grass-gui" is installed.
> Is this a bug or am I doing something wrong?
> Thank you
> Best
> Starting GRASS GIS...
> __________ ___ __________ _______________
> / ____/ __ \/ | / ___/ ___/ / ____/ _/ ___/
> / / __/ /_/ / /| | \__ \\_ \ / / __ / / \__ \
> / /_/ / _, _/ ___ |___/ /__/ / / /_/ // / ___/ /
> \____/_/ |_/_/ |_/____/____/ \____/___//____/
> Welcome to GRASS GIS 8.3.2
> GRASS GIS homepage: https://grass.osgeo.org
> This version running through: Bash Shell (/bin/bash)
> Help is available with the command: g.manual -i
> See the licence terms with: g.version -c
> See citation options with: g.version -x
> If required, restart the GUI with: g.gui wxpython
> When ready to quit enter: exit
> Launching <wxpython> GUI in the background, please wait...
> GRASS tmploc/PERMANENT:~ > Traceback (most recent call last):
> File "/usr/lib/python3/dist-packages/wx/core.py", line 3427, in <lambda>
> lambda event: event.callable(*event.args, **event.kw) )
> File "/usr/lib/grass83/gui/wxpython/wxgui.py", line 95, in show_main_gui
> mainframe = GMFrame(
> File "/usr/lib/grass83/gui/wxpython/main_window/frame.py", line 174, in __init__
> self.workspace_manager.CreateRecentFilesMenu(
> File "/usr/lib/grass83/gui/wxpython/lmgr/workspace.py", line 515, in CreateRecentFilesMenu
> file_menu = menu.GetMenu(
> wx._core.wxAssertionError: C++ assertion ""node"" failed at ./src/common/menucmn.cpp(923) in GetMenu(): bad index in wxMenuBar::GetMenu()
AFAIK the shipped wxPython version is too old.
You may try to update it:
pip3 install -U -f
https://extras.wxpython.org/wxPython4/extras/linux/gtk3/ubuntu-22.04
wxPython
Then GRASS GIS should start properly.
HTH,
Markus
Markus Neteler, PhD
https://www.mundialis.de - company
https://grass.osgeo.org - FOSS
https://neteler.org - freelancing & blog
