[GRASS-user] gdal_translate too many command options
sibylle.stoeckli at gmx.ch
Thu May 30 05:58:18 PDT 2024
Dear community
The main aim is to produce a mask of a raster file with data > 0
Code:
r.mask raster=ch_apple_presence_total_pollinator_abundance_spring
maskcats="0.01 thru 1"
ERROR: The raster map <ch_apple_presence_total_pollinator_abundance_spring>
must be integer (CELL type) in order to use the 'maskcats' parameter
Because of the error I followed the help here:
https://gis.stackexchange.com/questions/197145/error-in-r-thin-qgis-grass-in
put-raster-must-be-of-type-cell
However, wen running the code suggested with gdal_translate, I got an error
gdal_translate -co "ch_apple_presence_total_pollinator_abundance_spring "
ch_apple_presence_total_pollinator_abundance_spring.tif bit_
r.null map=ch_apple_presence_total_pollinator_abundance_spring setnull=1
gdal_translate -co ch_apple_presence_total_pollinator_abundance_spring
ERROR 6: Too many command options
'ch_apple_presence_total_pollinator_abundance_spring.tif'
Usage: gdal_translate [--help] [--help-general] [--long-
usage]
[-ot {Byte/Int8/Int16/UInt16/UInt32/Int32/UInt64/Int6
4/Float32/Float64/
CInt16/CInt32/CFloat32/CFloat64}] [-strict]
[-if <format>]... [-of <format>]
[-b <band>] [-mask <band>] [-expand {gray|rgb|rgba}]
[-outsize <xsize>[%]|0 <ysize>[%]|0] [-tr <xres>
<yres>]
[-ovr <level>|AUTO|AUTO-<n>|NONE]
[-r
{nearest,bilinear,cubic,cubicspline,lanczos,average,mode}]
[-unscale] [-scale[_bn] [<src_min> <src_max>
[<dst_min> <dst_max>]]]... [-exponent[_bn] <exp_val>]...
[-srcwin <xoff> <yoff> <xsize> <ysize>] [-epo] [-eco]
[-projwin <ulx> <uly> <lrx> <lry>] [-projwin_srs
<srs_def>]
[-a_srs <srs_def>] [-a_coord_epoch <epoch>]
[-a_ullr <ulx> <uly> <lrx> <lry>] [-a_nodata <value>]
[-a_gt <gt0> <gt1> <gt2> <gt3> <gt4> <gt5>]
[-a_scale <value>] [-a_offset <value>]
[-nogcp] [-gcp <pixel> <line> <easting> <northing>
[<elevation>]]...
|-colorinterp{_bn}
{red|green|blue|alpha|gray|undefined}]
|-colorinterp
{red|green|blue|alpha|gray|undefined},...]
[-mo <META-TAG>=<VALUE>]... [-q] [-sds]
[-co <NAME>=<VALUE>]... [-stats] [-norat] [-noxmp]
[-oo <NAME>=<VALUE>]...
<src_dataset> <dst_dataset>
Thanks a lot
Sibylle
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20240530/9fd280c3/attachment.htm>
