[GRASS-user] raster boxplots wrong assignment
sibylle.stoeckli at gmx.ch
Fri May 31 02:48:35 PDT 2024
Dear Micha
Thanks a lot interesting idea: Unfortunately I got a parse error. However the error/challenge is bevore selecting a specific region or site. I was able to plot one boxplot using a different code.
The challenge is that I use this code here to make “Quadrate/Squares” out of the vector layer “Untersuchungsquadrate”, because in r.boxplot you have input raster and zonal raster. Exactly in this code you make the assignment by defining attribute_column. I used both cat and ID_Quadrate, but it seems that my rasterized file “Quadrate” is not yet the one I need.
Ecodiv.earth - Boxplots based on raster data in GRASS GIS <https://ecodiv.earth/post/drawing-boxplots-of-raster-values/>
v.to.rast input=Untersuchungsquadrate_2020_2024 at PERMANENT output=Quadrate use=attr attribute_column=cat label_column="ID_Quadrat"
Sent: Friday, May 31, 2024 11:09 AM
To: sibylle.stoeckli at gmx.ch; grass-user at lists.osgeo.org
Subject: Re: [GRASS-user] raster boxplots wrong assignment
Hi Sibylle:
I'm not sure I fully understand the problem. If the below example is not relevant, just ignore...
I did a simple test using the nc_spm_08 location. The PERMANENT mapset includes an elevation raster 'elev_srtm_30m' and a categorical landcover raster 'landclass96'. I used the landcover raster as zones, and elevation for the values in the boxplots.
g.region -ap rast=elev_srtm_30m
# All landcover zones
r.boxplot input=elev_srtm_30m zones=landclass96 raster_statistics=median output=~/work/tmp/boxplot.png --o
# See attached boxplot image
# Now limit to only one zone, the forests, class 5 in this raster:
r.mapcalc "MASK = if(landclass96 == 5, 1, null())"
r.boxplot input=elev_srtm_30m zones=landclass96 raster_statistics=median output=~/work/tmp/boxplot_forest.png
# See attached boxplot_forest
r.mask -r
Hope this is somehow helpful.
On 31/05/2024 10:35, sibylle via grass-user wrote:
Dear community
I tested the r.boxplot addon and it is definitively possible to run the addon with more than 20 classes/regions/sites/squares.
Furthermore I realised the reason for the wrong assignment of class to raster, but I am not yet able to fix it.
1. The challenge is, that (at the moment) I have raster data for one class (one square), but in total I have 150 squares. So at the moment it just selects the first square (either by cat oder ID_Quadrat).
2. It seems however, if I have raster data for all squares, r.boxplot is working fine.
3. My question: Is it possible to assign raster data for one individual class/squares, of you have missing data for other classes/squares?
Kind regards
Sibylle
First using this code here:
v.to.rast input=Untersuchungsquadrate_2020_2024 at PERMANENT output=Quadrate use=attr attribute_column="ID_Quadrat" label_column="ID_Quadrat"
r.boxplot -o input=U803174_abgeschnitten zones=Quadrate bx_sort=ascending raster_statistics=median
Second using this code here:
From: sibylle.stoeckli at gmx.ch <mailto:sibylle.stoeckli at gmx.ch> <mailto:sibylle.stoeckli at gmx.ch> <sibylle.stoeckli at gmx.ch>
Sent: Thursday, May 30, 2024 9:27 AM
To: 'grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org> ' <mailto:grass-user at lists.osgeo.org> <grass-user at lists.osgeo.org>
Subject: RE: raster boxplots wrong assignment
Dear community
I am still wondering, if the r.boxplot addon is working with just a limited number of areass/sites/regions?
Kind regards
Sibylle
From: sibylle.stoeckli at gmx.ch <mailto:sibylle.stoeckli at gmx.ch> <sibylle.stoeckli at gmx.ch <mailto:sibylle.stoeckli at gmx.ch> >
Sent: Saturday, May 25, 2024 3:48 PM
To: 'grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org> ' <grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org> >
Subject: raster boxplots wrong assignment
Dear community
I would like to plot boxplots from a raster _pres_apple_spring_merged for different 1 km2 squares (38 squares, Fig. 1, layer “Untersuchungsquadrate”). I was using the same code as used before for 12 regions:
https://ecodiv.earth/post/drawing-boxplots-of-raster-values/ (Author Paulo van Breugel). All layers have the same projection (EPSG:2056, CH1903+/LV95). However, when loading the layer squares (Untersuchungsquadrate) GRASS GIS was asking for reprojection.
1. I got now a warning message, that I have a lot of categories, however, the modelling time was fast (Fig 2)
2. The error is now, that the boxplot is not showing all squares (e.g. ID_Quadrat 803174) and the boxplots are assigned to the wrong square (ID_Quadrat) (Fig. 3)
Kind regards
Sibylle Stöckli
Fig. 1
Fig. 2
Figure 3
grass-user mailing list
https://lists.osgeo.org/mailman/listinfo/grass-user
Micha Silver
Ben Gurion Univ.
Sde Boker, Remote Sensing Lab
cell: +972-523-665918
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20240531/596ba5ee/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20240531/596ba5ee/attachment-0007.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20240531/596ba5ee/attachment-0008.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20240531/596ba5ee/attachment-0009.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20240531/596ba5ee/attachment-0010.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20240531/596ba5ee/attachment-0011.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20240531/596ba5ee/attachment-0012.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20240531/596ba5ee/attachment-0013.png>
