[GRASS-user] Segmentation : how to add texture criterion ? (not only colour/spectral variable)
Veronica Andreo
veroandreo at gmail.com
Tue Mar 4 14:32:46 PST 2025
Hello Laurent,
You might want to check i.segment [0] within the core tools of GRASS and
i.segment.uspo [1] for unsupervised parameter optimization within GRASS
extensions. Also, there are nice papers by Grippa et al [2] and Georganos
et al [3] that show the segmentation/OBIA workflow within GRASS.
To include texture rasters within segmentation, have a look at
r.texture [4] tool in GRASS. What I usually do is to estimate textures from
a panchromatic higher res band.
hth,
Vero
[0] https://grass.osgeo.org/grass-stable/manuals/i.segment.html
[1] https://grass.osgeo.org/grass-stable/manuals/addons/i.segment.uspo.html
[2] https://doi.org/10.3390/rs9040358
[3] https://doi.org/10.3390/rs10091440
[4] https://grass.osgeo.org/grass-stable/manuals/r.texture.html
El mar, 4 mar 2025 a las 12:20, Laurent CELATI via grass-user (<
grass-user at lists.osgeo.org>) escribió:
> Hello.
> My goal is to generate a relevant segmentation that would delimit the main
> physiopnomic units (homogenous areas). Up to now, I have done several tests
> with qgis and orfeotoolbox 9 with the OTB Generic Region merging module : GenericRegionMerging
> — Orfeo ToolBox 7.0.0 documentation
> <https://www.orfeo-toolbox.org/CookBook-7.0/Applications/app_GenericRegionMerging.html>
> with those folowing settings
> - input image : spot 6/7 satelite image (band blue, green, red, near
> infrared)
> or Aerial french mapping agency images (50 cms bd ortho with green,
> red and near infrared).
> - Homogenity criterion to use : Baatz & Schape
> - Threshold for the criterion : 500
> - Number of iterations`: 0
> - Weight for the spectral homogeneity : 0.1
> - Weight for the spatial homogeneity : 0.1
> The result is rather interesting for certain areas, in particular crops
> areas, without too much vegetation. on the other hand, the method does not
> seems optimal, in particular for forest areas.
> Perhaps for these forest areas, the color/spectral criterion is not
> relevant. It would be better to generate / integrate texture information?
> As far as i understood, this GRM OTB module is based only on
> spectral/colour criterion but not take into consideration texture
> information.
> Are there other qgis/grass/ orfeotoolbox or whatever other segmentation
> module that takes into account not only the color criterion (spectral) but
> also texture information?
> If this is not the case, should i create some kind of new raster (add a
> band to my existing color infrared raster) dedicated to texture and/or ndvi
> information?
> Thanks so much for your guidances.
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
Dra. Verónica Andreo
Investigadora Adjunta de CONICET
Instituto Gulich (CONAE - UNC)
Centro Espacial Teófilo Tabanera (CETT)
Falda del Cañete - Córdoba, Argentina
+54 3547 400000 int. 1153
https://veroandreo.gitlab.io/
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20250304/3c9b74d2/attachment.htm>
