[GRASSweb-list](no subject)
Erika K. Crosse eyreka at mac.com
Sat Aug 3 15:05:25 EDT 2002
I am re-sending request below through my mac.com account as some
mysterious malady has  disabled my sympatico service.  Hopefully I WILL
be able to receive e-mail in this account --- my IP remains sympatico.
Hello,
I just got around to installing my update of GRASS 5.0.0pre4 from
OpenOSX and find I've a problem with the TlcTkGRASS gui. I don't
currently use the GUI but will want to do so and would appreciate any
help getting it going again.
When I give the command tlctkgrass& as below
GRASS 5.0.0pre4 > tcltkgrass&
the main menu bar briefly appears and then I get the message:
[1] 456
Mapset <PERMANENT> in Location <leics>
GRASS 5.0.0pre4 > Error in startup script: can't read
"env(TCLTKGRASSBASE)": no such variable
    while executing
"subst $monitors_menu"
    ("uplevel" body line 1)
    invoked from within
"uplevel #0 subst $element"
    (procedure "menu_build" line 28)
    invoked from within
"menu_build 0 $menupath $element"
    (procedure "menu_build" line 61)
    invoked from within
"menu_build 1 .main_menu {
    Config "Configuration of TclTkGRASS" {
        Monitors "" $monitors_menu
        "Module windows" "" {
            "Aut..."
    (file "/usr/local/grass5/tcltkgrass/main/menu.tcl" line 232)
    invoked from within
"source $env(TCLTKGRASSBASE)/main/menu.tcl
    (file "/usr/local/grass5/bin/tcltkgrass" line 24)
[1]    Exit 1                        tcltkgrass
GRASS 5.0.0pre4 >
If I open the Terminal and query as below:
Welcome to Darwin!
[localhost:~] eyreka% which xwininfo
/usr/X11R6/bin/xwininfo
[localhost:~] eyreka% ls /usrX11R6/bin/xwininfo
ls: /usrX11R6/bin/xwininfo: No such file or directory
I also ran command below
[localhost:~] eyreka% echo $path | grep /usr/X11R6/bin
and got
/sw/bin /sw/sbin /Users/eyreka/bin/powerpc-apple-darwin
/Users/eyreka/bin /usr/local/bin /usr/bin /bin /usr/local/sbin /usr/sbin
/sbin /usr/local/teTeX/bin/powerpc-apple-darwin1.3.7 /usr/X11R6/bin
/usr/X11R6/bin
Can you rescue me again?
One thing different this time is that I recently downloaded the fink
0.4.0 installer package and  ran selfupdate-cvs.
   Erika Crosse
   OpenOSX order info:
   Peter E. Fischer, Thornhill, ON
       ---  order # 1698-5017-6114
More information about the grass-web mailing list
