[GRASSweb-list]markus: web/grass51 examples.html,1.17,1.18
    grass at intevation.de
    Sat Dec 14 03:31:53 EST 2002
        - Previous message: [GRASSweb-list]markus: web/gdp index.html,1.32,1.33
- Next message: [GRASSweb-list]markus: web/grass51 tutorial.html,NONE,1.1 attrib_storage.html,1.2,1.3 examples.html,1.18,1.19 geom_storage.html,1.2,1.3
-  Messages sorted by:
              [ date ]
              [ thread ]
              [ subject ]
              [ author ]
Author: markus
Update of /grassrepository/web/grass51
In directory doto:/tmp/cvs-serv21066
Modified Files:
	examples.html
Log Message:
v.db.connect, v.patch, url
Index: examples.html
RCS file: /grassrepository/web/grass51/examples.html,v
retrieving revision 1.17
retrieving revision 1.18
diff -u -d -r1.17 -r1.18
--- examples.html	11 Dec 2002 17:48:58 -0000	1.17
+++ examples.html	14 Dec 2002 08:31:51 -0000	1.18
@@ -46,8 +46,8 @@
 <li>nviz
 <li>v.build v.clean.test  v.in.ascii  v.rand.poly
     v.topo.check v.build.polylines v.convert v.info v.shape.register
-    v.category v.digit v.out.ascii v.shape.unregister v.clean v.extract
-    v.out.ogr v.surf.rst
+    v.category v.db.connect v.digit v.out.ascii v.patch v.shape.unregister
+    v.clean v.extract v.out.ogr v.surf.rst
 <li>
 If you start a module just by name, a related <a
                                          href=http://mpa.itc.it/radim/g51/d.vect-gui.jpg>GUI window pops up</a>.
@@ -287,6 +287,9 @@
 <ul>
 <li><a href=http://postgis.refractions.net/>PostGIS with shp2pgsql</a>:<br>
           <tt>shp2pgsql -D lakespy2 lakespy2 test > lakespy2.sql</tt>
+<li><a href=http://www.postgresql.org/>PostgreSQL</a> and
+    <a href=http://techdocs.postgresql.org/>PostgreSQL Technical
+     Documentation</a>
 <li><a href=http://www.klaban.torun.pl/prog/pg2xbase/>pg2xbase</a>
                   (DBF <-> PostgreSQL)
 <li><a href=http://e00pg.sourceforge.net/>e002pg</a> (E00 to PostGIS
              [ date ]
              [ thread ]
              [ subject ]
              [ author ]
More information about the grass-web
