[GRASSweb-list]markus: web/statsgrass grass_r_insthints.html,1.10,1.11
grass at intevation.de grass at intevation.de
Thu Dec 19 13:50:48 EST 2002
Author: markus
Update of /grassrepository/web/statsgrass
In directory doto:/tmp/cvs-serv16384
Modified Files:
Log Message:
another note
Index: grass_r_insthints.html
RCS file: /grassrepository/web/statsgrass/grass_r_insthints.html,v
retrieving revision 1.10
retrieving revision 1.11
diff -u -d -r1.10 -r1.11
--- grass_r_insthints.html	19 Dec 2002 18:46:21 -0000	1.10
+++ grass_r_insthints.html	19 Dec 2002 18:50:46 -0000	1.11
@@ -76,12 +76,15 @@
 <a href=http://www.stats.ox.ac.uk/pub/Rtools/>R/Windows Installation hints</a>
 Preparation:
- - You have to add c:\Perl\bin in the PATH variable of Windows
+ - You have to add c:\Perl\bin in the PATH variable of Windows (CHECK: really needed?)
  - To bypass Cygwin's path and make sure that MinGW and Perl are the first
    directories in the Cygwin path. So, one needs to modify the /etc/profile
    file AND any user defined resource file in their home directory
    (i.e. a ~/.bash_profile that needed updating too - don't know why but it
-   does). If ~/.bash_profile is not present, make it a copy of /etc/profile
+   does). If ~/.bash_profile is not present, make it a copy of /etc/profile.
+   In /etc/profile change the PATH= definition so that $PATH comes first
+   (per default it comes last). Something like
+   PATH="$PATH:/usr....."
  - rw1060\bin - that can be put in the path too (or rw1062\bin or ...)
  - When you installed R from rw1060.exe, you should have accepted the default
    install of source package installation files too.
More information about the grass-web mailing list
