[GRASSweb-list]markus: web/grass51/tutorial demo.html,NONE,1.1
grass at intevation.de grass at intevation.de
Tue Dec 31 10:03:59 EST 2002
Author: markus
Update of /grassrepository/web/grass51/tutorial
In directory doto:/tmp/cvs-serv19870
Added Files:
	demo.html
Log Message:
5.1 demo tour
--- NEW FILE: demo.html ---
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
   <DEFANGED_meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
   <DEFANGED_meta name="Author" content="Markus Neteler">
   <DEFANGED_link rel="stylesheet" type="text/css" href="../../sitestyle.css">
   <title>GRASS 5.1: A quick demo tour</title>
</head>
<body>
<!-- HEADER -->
<table width=100%><tr><td width=80>
<A HREF="index.html">
<DEFANGED_IMG src="../../images/grass.smlogo.gif" alt="HOME" border="0" align=middle></A>
</td><td><H1>
</H1></td></tr></table>
<!-- END OF HEADER -->
<hr>
<a href="index.html">Tutorial HOME</a> |
<a href="demo.html">Demo LOCATION</a> |
<a href="geom_storage.html">Geometry management</a> |
<a href="attrib_storage.html">Attribute management</a> |
<a href="examples.html">Usage Examples</a>
<hr>
<i><b>README:</b>
GRASS 5.1 is currently under development. It is neither complete (it still
contains only a few modules) nor it is intended to productional usage.
Development releases are provided for people who want to help test, debug,
and improve GRASS 5.1. Knowing this, please read on.</i><br>
<i>
These examples described here may work or not. You are kindly invited to
send us further examples and/or code bugfixes/enhancements.</i>
<P>
<h2>A quick demo tour</h2>
First download the <a href="http://mpa.itc.it/radim/g51/">Sample GRASS 5.1
LOCATION</a> which is used throughout this tutorial.
<p>
The sample LOCATION "g51test" contains a script which demonstrates most
features of the new vector engine. To run this demo, start GRASS 5.1 with
the sample LOCATION "g51test-X" (X is the current version of the data set)
and the mapset "test". In the LOCATION directory you will find the
<tt>./tour</tt> shell script (example):
<div class="code"><pre>
grass51 /home/username/grassdata51/g51test-8/test/
</div></pre>
After entering GRASS, change into the LOCATION directory and start the demo
tour:
cd /home/username/grassdata51/g51test-8/
g.region -dp
./tour
</div></pre>
The README file in this directory contains descriptions of the sample maps.
<p>
Note: If the tour fails at a certain step, the version of the "g51test-X"
LOCATION does not correspond to current GRASS 5.1 version as installed on
your computer. Be sure to use latest code and sample data set. If this
doesn't help: congratulations, you have found a bug. Please report it to the
development team.
<h2>Further tests</h2>
Further tests can be done with following scripts in the same directory:
<ul>
<li><tt>./io</tt><br>
- imports 'mcat' and 'multi' ascii files from PERMANENT mapset to current
mapset, export again and compare with original files. Original and exported
files should be identical.</li>
<li><tt>./genet</tt><br>
- creates a 2D vector network "net" with attributes stored in a DBF file.
 Display it with:
 d.vect net
 nviz el=dem vect=net
 v.db.connect net
 v.info net
 </div></pre></li>
<li><tt>./gen.big</tt><br>
- generate big ascii file. Usage:
 ./gen.big output=name [n=value] [type=] [attr=value] [ver=value] [shape=value]
 </div></pre>
with: <br>
<i> &nbsp;&nbsp; n: number of rows and columns (def.: 10) <br>
 &nbsp;&nbsp; type: primitive type (def.: "plbc", point, line, boundary, centroid) <br>
 &nbsp;&nbsp; attr: y/n write attributes (def.: y) <br>
 &nbsp;&nbsp; ver: GRASS 5/4 version (def.: 5) <br>
 &nbsp;&nbsp; shape: area shape: r - rectangles, s - suns (def.: r)
</i>
<br>
 Example (takes a while, generates 100 * 100 = 10000 lines with 10000 areas
 with circle shape and 10000 islands):
 ./gen.big output=bigmap n=100 shape=s
 v.in.ascii in=bigmap out=bigmap
 v.info bigmap
 d.vect bigmap
 d.zoom
 d.vect bigmap display=shape,cat lcolor=green
 </div></pre></li>
<li><tt>./gen.long</tt><br>
- generates a long line (curve)
 ./gen.long output=name [npoints=value]
 </div></pre>
with: <br>
<i> &nbsp;&nbsp; npoints: number of vertices (def.: 1000000)
</i>
<br>
 Example:
 ./gen.long output=longcurve npoints=10000
 v.in.ascii in=longcurve out=longcurve
 v.info longcurve
 v.db.connect longcurve
 g.region vect=longcurve -p
 d.erase
 d.vect longcurve
 d.zoom
 </div></pre></li>
<li><tt>./bench</tt><br>
- comparison between two formats: native x PostGRASS (using PostGIS)
<br>
Example: todo.
</li>
</ul>
The other scripts stored in the LOCATION directory are internally used by
some demo scripts.
<!-- FOOTER -->
<p>
<hr>
<DIV ALIGN=right>&copy; 2002 Markus Neteler<br>
<a href="mailto:weblist at grass.itc.it">Comments</a> about this page | <a href="../../faq/index.html">FAQ</a> | <a href="../../download.html">Download</a> | <a href="../../support.html">Support</a> | <a href="../../gdp/index.html">Docs</a>  | <a href="../../grassdevel.html">Programming</a> | Back <a href=index.html>5.1 Tutorial Home</a><br>
<i>Last change:
$Date: 2002/12/31 15:03:57 $
</i></DIV>
</body>
</html>
More information about the grass-web mailing list
