[GRASSweb-list]library problem..
Bernhard Reiter bernhard at intevation.de
Thu Jul 18 05:40:22 EDT 2002
The homepage of the ncurses library is:
	http://www.gnu.org/software/ncurses/ncurses.html
GRASS can use alternative libraries, maybe your system administrator
should advise you and help to build grass from source.
Then it will use the libraries you already have on your system.
Hope this helps,
	Bernhard Reiter
On Thu, Jul 18, 2002 at 10:57:09AM +0530, Dr. D.S. Arya wrote:
>    I have installed grass5 on solaris 8 successfully. But when I run the
>    s/w it gives error that file libncurses.so.5 is not found. This file
>    is not available with the OS. When searched over Internet, it is found
>    a linux library file. Could you please tell me where from this file be
>    downloded?
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-web/attachments/20020718/127fd20e/attachment.bin
More information about the grass-web mailing list
