[GRASSweb-list]New GRASS contact address: weblist@grass.itc.it
    Markus Neteler
    neteler at itc.it
    Mon May 13 10:22:17 EDT 2002
to help 'grass at baylor.edu' with the management of requests I have set up
another mailing list:
 weblist at grass.itc.it
 http://grass.itc.it/mailman/listinfo/weblist
It manages requests which are not sent to one of the GRASS mailing lists
(eg information requests etc).
The address 'weblist at grass.itc.it' points to an open list which does not
require subscription. The address 'grass at baylor.edu' is of course
subscribed so that effectively nothing should change for you (except
a potential reduction in workload). Only problem is spam which we may
block similar to the RT bugreport list. Of course 100% spam protection
is impossible.
When now people click on the "send your GRASS related email" it is
sent to 'weblist at grass.itc.it' first which distributes the message
to 'grass at baylor.edu' and other subscribers like some developers.
As discussed this will give more insights into the user needs and
should also reduce workload for 'grass at baylor.edu' maintainers
(because the other subscribers may also answer requests, you are welcome
to join).
So 'weblist at grass.itc.it' is the subscription-free channel to contact
GRASS people.
Best regards
 Markus Neteler
More information about the grass-web
