[GRASSweb-list]markus: web/faq index.html,1.3,1.4
grass at intevation.de grass at intevation.de
Sat May 25 13:27:52 EDT 2002
Author: markus
Update of /grassrepository/web/faq
In directory doto:/tmp/cvs-serv9327
Modified Files:
Log Message:
simplified
Index: index.html
RCS file: /grassrepository/web/faq/index.html,v
retrieving revision 1.3
retrieving revision 1.4
diff -u -d -r1.3 -r1.4
--- index.html	26 Mar 2002 09:21:12 -0000	1.3
+++ index.html	25 May 2002 17:27:50 -0000	1.4
@@ -152,12 +152,12 @@
 of specific file formats into GRASS:</font></font></i></b>
 <ul>
 <li>
-<font face="Arial, Helvetica"><font size=+0>Check the list of import tools
-<a href="../gdp/html_grass5/import.html">GRASS
-5 Import overview</a></font> for the desired format</font></li>
+<font face="Arial, Helvetica"><font size=+0>
+<a href="../gdp/html_grass5/import.html"><B>GRASS
+5 Import overview</B></a></font> for the desired format</font></li>
 <li>
-See also f<font face="Arial, Helvetica">urther documents:</font></li>
+<font face="Arial, Helvetica">See also further extra documents:</font></li>
 <ul>
 <li>
@@ -176,7 +176,12 @@
 <li>
 <font face="Arial, Helvetica"><font size=+0>Import: <a href="gtopo30_import.html">GTOPO30
 world digital elevation data</a></font></font></li>
+</ul>
+<a href="../gdp/html_grass5/export.html"><B>GRASS
+5 Export overview</B></a></font> for the desired format</font></li>
+<ul>
 <li>
 <font face="Arial, Helvetica"><font size=+0>Export: How can I export overlayed
 raster and vector maps in <b>one</b> file? <a href="celldriver.html">Use
@@ -185,95 +190,13 @@
 <li>
 <font face="Arial, Helvetica"><font size=+0>Export: How can I <a href="grass_coreldraw.html">convert
 my GRASS maps to CorelDraw?</a></font></font></li>
-<li>
-<font face="Arial, Helvetica"><font size=+0><b>GRASS 5.x: </b>Import of
-ESRI files</font></font></li>
-<ul>
-<li>
-<font face="Arial, Helvetica"><font size=+0><a href="../gdp/html_grass5/html/v.in.arc.html">v.in.arc</a>
-(UNGEN format),</font></font></li>
-<li>
-<font face="Arial, Helvetica"><font size=+0><a href="../gdp/html_grass5/html/v.in.shape.html">v.in.shape</a>,</font></font></li>
-<li>
-<font face="Arial, Helvetica"><font size=+0><a href="../gdp/html_grass5/html/m.in.e00.html">m.in.e00</a>
-(raster and vector), and</font></font></li>
-<li>
-<font face="Arial, Helvetica"><font size=+0><a href="../gdp/html_grass5/html/r.in.arc.html">r.in.arc</a>
-(ARC-Grid)</font></font></li>
-</ul>
-<li>
-<font face="Arial, Helvetica"><font size=+0><b>GRASS 5.x: </b>Export into
-ESRI-formats:</font></font></li>
-<ul>
-<li>
-<font face="Arial, Helvetica"><font size=+0><a href="../gdp/html_grass5/html/v.out.arc.html">v.out.arc</a>
-<li>
-<font face="Arial, Helvetica"><font size=+0><a href="../gdp/html_grass5/html/v.out.e00.html">v.out.e00</a>
-(E00 format),</font></font></li>
-<li>
-<font face="Arial, Helvetica"><font size=+0><a href="../gdp/html_grass5/html/r.out.arc.html">r.out.arc</a>
-</ul>
-<li>
-<font face="Arial, Helvetica"><font size=+0><b>GRASS 5.x: </b>Alternative
-vector exchange formats:</font></font></li>
-<ul>
-<li>
-<font face="Arial, Helvetica"><font size=+0><a href="../gdp/html_grass5/html/v.in.dxf.html">v.in.dxf</a>
-(DXF format),</font></font></li>
-<li>
-<font face="Arial, Helvetica"><font size=+0><a href="../gdp/html_grass5/html/v.out.dxf.html">v.out.dxf</a>
-<li>
-<font face="Arial, Helvetica"><font size=+0><a href="../gdp/html_grass5/html/v.in.dlg.html">v.in.dlg</a>
-(DLG format),</font></font></li>
-<li>
-<font face="Arial, Helvetica"><font size=+0><a href="../gdp/html_grass5/html/v.out.dlg.html">v.out.dlg</a>
-</ul>
-<li>
-<font face="Arial, Helvetica"><font size=+0><b>GRASS 4.x: </b>Import of
-ESRI files:</font></font></li>
-<ul>
-<li>
-<font face="Arial, Helvetica"><font size=+0>Import: <a href="shape_import.html">SHAPE
-vector files</a></font></font></li>
-<li>
-<font face="Arial, Helvetica"><font size=+0>Import: <a href="http://tulip.itc.nrcs.usda.gov/docs/GRASS_Documentation.html">ARC/INFO
-vector files</a>- <i>from NRCS/USDA</i></font></font></li>
-<li>
-<font face="Arial, Helvetica"><font size=+0>Import: <a href="e00_import.html">e00
-<li>
-<font face="Arial, Helvetica"><font size=+0>Import: <a href="arcgrid.header.html">ARC/INFO
-ASCII grid file</a></font></font></li>
-</ul>
 </ul>
 <li>
 <font face="Arial, Helvetica"><font size=+0>Conversion: <a href="xy_to_utm.html">GRASS
 conversion xy-data to UTM</a></font></font></li>
 </ul>
 <a NAME="problems"></a><b><i><font face="Arial, Helvetica"><font size=+0>Common
 problems and Frequently asked questions</font></font></i></b>
 <ul>
More information about the grass-web mailing list
