[GRASSweb-list]markus: web/grass51 examples.html,1.7,1.8 index.html,1.34,1.35
grass at intevation.de grass at intevation.de
Tue Nov 5 10:38:00 EST 2002
Author: markus
Update of /grassrepository/web/grass51
In directory doto:/tmp/cvs-serv27350
Modified Files:
	examples.html index.html
Log Message:
a bit more
Index: examples.html
RCS file: /grassrepository/web/grass51/examples.html,v
retrieving revision 1.7
retrieving revision 1.8
diff -u -d -r1.7 -r1.8
--- examples.html	5 Nov 2002 13:33:55 -0000	1.7
+++ examples.html	5 Nov 2002 15:37:57 -0000	1.8
@@ -8,19 +8,24 @@
 <body text="#000000" bgcolor="#FFFFFF" link="#0000EF" vlink="#59188E" alink="#FF0000">
 <font face="Arial, Helvetica">
-<h1>GRASS 5.1 Usage Examples</h1>
+<table width="100%" cellpadding="3" border="0">
+<tr><td align="left" bgcolor="#10ef40"><font color="#00000" face="Helvetica"><big><b>
+GRASS 5.1 Usage Examples
+</b></big></font></td></tr></table><p>
-GRASS 5.1 is currently under development. It is neighter complete (it still
+GRASS 5.1 is currently under development. It is neither complete (it still
 contains only a few modules) nor it is intended to productional usage.
 Development releases are provided for people who want to help test, debug,
 and improve GRASS 5.1. Knowing this, please read on.
 <p>
-<i><b>Disclaimer:</b> These examples may work or not. You are kindly invited to send us
-further examples and/or code bugfixes/enhancements.<i>
+<i><b>Disclaimer:</b> These examples described here may work or
+        not. You are kindly invited to send us further examples and/or
+        code bugfixes/enhancements.<i>
 <P>
-Do get debug information, set variable (set to 0 for debug silence):
+To get debug information, set variable (set to 0 for debug silence) to
+      1..5:
 <pre>
 export GRASS_DEBUG_LEVEL=5
 </pre>
@@ -338,12 +343,59 @@
 <pre>
-#Select from table 'markveggy' (in database 'grass51test') all rows where 'vegtype = "IFA"':
+#First we want to read from the DBF table:
+#NOTE: connections for db.* SQL commands (eg db.select...) are established with db.connect:
+db.connect driver=dbf database=/ssi0/ssi/neteler/grassdata/botswanaLL/shp
+#Select from table 'markveggy' (in database 'grass51test') all rows where 'VEGTYPE = "IFA"':
 #NOTE: string attributes must be quoted:
-echo "select * from markveggy where vegtype = 'IFA'" | db.select -ch
+echo "select VEGCNP_ID from markveggy where VEGTYPE = 'IFA'" | db.select -hc
+#NOTE: vector commands use connection(s) defined in DB file (see above):
+#add line
+markveggy.vegtype 1 markveggy VEGCNP_ID /ssi0/ssi/neteler/grassdata/botswanaLL/shp dbf
+#NOTE: for areas such selections only work when area centroids are present!
+d.erase
+d.vect markveggy.vegtype where="VEGTYPE = 'IFA'"
+d.what.vect -a
+#Now connection to PostgreSQL through ODBC:
+db.connect driver=odbc database=grass51test
+#add line to DB file to connect vector map
+markveggy.vegtype 1 markveggy VEGCNP_ID grass51test odbc
+d.erase
+d.vect markveggy.vegtype where="VEGTYPE = 'Wiii'"
+d.what.vect -a
-#to be cont'ed...
 </pre>
+<hr>
+<b>Further Links:</b>
+<ul>
+<li><a href=http://postgis.refractions.net/>PostGIS with shp2pgsql</a>:<br>
+          <tt>shp2pgsql -D lakespy2 lakespy2 test > lakespy2.sql</tt>
+<li><a href=http://www.klaban.torun.pl/prog/pg2xbase/>pg2xbase</a>
+                  (DBF <-> PostgreSQL)
+<li><a href=http://e00pg.sourceforge.net/>e002pg</a> (E00 to PostGIS
+                  filter)
+<li><a href=http://gdal.velocet.ca/projects/opengis/>ogrinfo and
+                    ogr2ogr</a> (GIS vector format converter and
+                  library, e.g. ArcInfo or SHAPE -> PostGIS)<br>
+          <tt>ogr2ogr -f "PostgreSQL" shapefile ??</tt>
+<li><a href=http://mdbtools.sourceforge.net/>mdbtools</a> (converts
+                  MS-ACCESS data to SQL, DBF etc.)<br>
+          <tt>gmdb dbfile.mdb</tt>
+<li><a href=http://www.unixodbc.org/>unixODBC</a> to connect GRASS 5.1
+                  to database servers such as PostgreSQL, Oracle etc.
+</ul>
 <!-- FOOTER -->
 <p>
Index: index.html
RCS file: /grassrepository/web/grass51/index.html,v
retrieving revision 1.34
retrieving revision 1.35
diff -u -d -r1.34 -r1.35
--- index.html	30 Oct 2002 16:55:34 -0000	1.34
+++ index.html	5 Nov 2002 15:37:57 -0000	1.35
@@ -16,7 +16,7 @@
 <h1><font face="Arial, Helvetica">GRASS 5.1 status</font></h1>
+GRASS 5.1 is currently under development. It is neihter complete (it still
More information about the grass-web mailing list
