[GRASSweb-list]markus: web/statsgrass grass_r_insthints.html,1.5,1.6
grass at intevation.de
Tue Nov 5 11:22:24 EST 2002
Author: markus
Update of /grassrepository/web/statsgrass
In directory doto:/tmp/cvs-serv28168
Modified Files:
Log Message:
a bit more
Index: grass_r_insthints.html
RCS file: /grassrepository/web/statsgrass/grass_r_insthints.html,v
retrieving revision 1.5
retrieving revision 1.6
diff -u -d -r1.5 -r1.6
--- grass_r_insthints.html 31 Oct 2002 16:59:36 -0000 1.5
+++ grass_r_insthints.html 5 Nov 2002 16:22:22 -0000 1.6
@@ -70,13 +70,23 @@
- Installing R contribution packages requires that <a href=http://www.cpan.org/ports/index.html#win32>Perl 5.005</a> or later be installed.
(e.g. <a href=http://www.activestate.com/Products/ActivePerl/Download.html>ActivePerl</a>)
-In general winGRASS under Cygwin is able to talk to R/MS-Windows.
+In general winGRASS under Cygwin is able to talk to R/MS-Windows (<a href=http://cran.at.r-project.org/bin/windows/contrib/rw-FAQ.html>R/Windows FAQ</a>)
-Installation of the GRASS/R interface:
- - Instead of '/usr/bin/R' use 'Rcmd'
- - See command above (UN*X part).
+<a href=http://www.stats.ox.ac.uk/pub/Rtools/>R/Windows Installation hints</a>
-NOTE 0: Enjoy the <a href=http://cran.at.r-project.org/bin/windows/contrib/rw-FAQ.html>R/Windows FAQ</a>
+You have to add also c:\Perl\bin in the PATH variable of Windows. And also, to
+bypass Cygwin's path and make sure that MinGW and Perl are the first directories
+in the Cygwin path. So, one needs to modify the /etc/profile file AND any user
+defined resource file in their home directory (i.e. a ~/.bash_profile that needed
+updating too - don't know why but it does).
+rw1060\bin - that can be put in the path too.
+When you installed R from rw1060.exe, you should have accepted the default
+install of source package installation files too.
+Then, installation of the GRASS/R interface:
+ - Instead of '/usr/bin/R' use 'Rcmd'
+ - See further command above (UN*X part).
NOTE 1: When using the GRASS/R interface, ignore (if appearing) strange error messages
which are generated by the GRASS/R interface.
@@ -84,14 +94,14 @@
NOTE 2: We also succeeded to run R in GRASS on Cygwin in batch mode.
-[Useful link? http://www.stats.ox.ac.uk/pub/Rtools/]
<hr>
Future: Once the GRASS/R interface reaches the standard contrib space on the R web
site, the options() command and install.packages() will work and simplify
the installation.
</pre>
+(You are kindly invited to improve this page as send it to us)
<!-- FOOTER -->
<hr>
<DIV ALIGN=right>© 2001-2002 GRASS Development Team<br>
More information about the grass-web
