[GRASSweb-list]markus: web/oldprojects/postgrass index.html,NONE,1.1
grass at intevation.de grass at intevation.de
Sat Nov 9 17:44:57 EST 2002
Author: markus
Update of /grassrepository/web/oldprojects/postgrass
In directory doto:/tmp/cvs-serv27933
Added Files:
Log Message:
was projects/
--- NEW FILE: index.html ---
<html>
<head><title>Postgres v6.4 / Grass - initial rewrite</title>
</head>
<body bgcolor=#FFFFe0>
<b>Welcome to Postgres v6.4 / Grass - initial rewrite</b>
<br><br>
<i>15. Nov. 1998</i>
<pre>
This area is working code for Postgres/Grass interface routines
<a href=postgrass_nov98b.tar.gz>Download files</a> (32 kb)
<br>
Warning - headers and disclaimers are incomplete
This code is not stable and may cause severe problems on your system.
Modules (working) in above package:
d.site.pg
d.vect.pg
d.what.s.pg
g.select.pg
g.stats.pg
g.column.pg
g.table.pg
d.what.s.pg
        text_functions.sql      - needed for g.stats.pg
                                - should be in system functions but alas....
I have compiled these on a linux i386 RH5.1 (plus some other stuff) system,
and tested them againt Postgres v6.4 database.
See <a href=d.site.pg-libs>d.site.pg-libs</a> / <a href=d.vect.pg-libs>d.vect.pg-libs</a> for linked library list
on my machine.
My Postgres version was 6.3 at the start of coding and 6.4 at the end.
All routines were tested against 6.4, g.select.pg and d.site.pg were tested
against 6.3.
Compiling   ( on linux RH5.1 )
     edit grass42/src/CMD/head/<port>
        add PQINCPATH = /usr/local/psql/include
            or whereever Postgres includes are on your system
        add PQLIB = -L/usr/local/pgsql/lib -lpq -lcrypt
            see Postgres documentation of libpq for flags for you specific port
See example <a href=linux>Linux head file</a>.
Don't forget to add d.site.pg, g.select.pg, g.table.pg, d.vect.pg to lists/GRASS
and then run grass42/src/CMD/MAKELINKS.my
Thses routines have been cleaned up to have only one block of code drawing on
the display.  All other routines only construct a SQL statement and pass it
along.  The seperation of builidng the queries and running the queries should
be more flexible as time goes by.
I don't understand the need for a join statement in the interactive portions.
I want to strip it out force users who have complex queries to use the read
from file option instead (anyway it seems to be strictly postquel specific).
To assist users understand SQL statements I added a message listing the exact
SQL statement being executed.
I added pghost support to all the programs I have worked on.
It defaults to NULL if not entered. (and thus the environment variable PGHOST
or if that is not set then localhost)
I broke from the
    psql < infile > outfile
style interface when I was trying to get it to work against a lat/long database.
The data completely filled the column, causing the scanf on the buffer to fail.
Libpq is easier and safer and should ultimately give better performance as
transactions can be run with conditional testing by the program inside the block.
Transactions can be established in the psql < infile style but each block must
end before the outfile is available. Additioanlly libpq supports binary (native
format)
Man libpq on your system if any postgres95 or later has been installed.
Three excellent sample programs are there.
In addition to these catagoery support queries from Postgres, I want to add
direct drawing of the postgres data types point,line,path,and polygon.
But I think that a one-to-one relationship between shapes and attributes may be
worthwhile, in that case new data type will have to be constructed.
Does anyone think that forcing sites to be a single column of point class will cause
user too much trouble.  They can still create a view such as
  create view testvw as select lat,long,point(lat,long) as well_loc,cat
      from wells;
and then use the view as the table to query
  d.site.pg tab=testvw coord=well_loc, cat=cat plot=red,x,2
Using the point greatly reduces the complexity of the select statement for the
query in d.what.s.pg.
/* Postquel query by J.Soimasuo */
	  fprintf(fp,"SELECT unique (%s.all) \n",
		ktab->answer);
	  fprintf(fp,"where ( ( (%s.%s - %f) * (%s.%s - %f) +\n",
		ktab->answer,xcol->answer, pts->centX,
		ktab->answer,xcol->answer, pts->centX);
	  fprintf(fp,"(%s.%s - %f) * (%s.%s - %f) ) < %f )\n",
		ktab->answer,ycol->answer, pts->centX,
		ktab->answer,ycol->answer,pts->centY, pts->rad2 );
/* Postgres Spatial Query */
    sprintf(SQL_stmt,
     "SELECT * from %s where point(%s,%s) @ '(%f,%f,%f,%f)'::box",
           ktab->answer, xcol->answer,ycol->answer,
           pts->minX, pts->minY, pts->maxX, pts-> maxY);
/* use Postgres graphic operators
/*               @ operator tests for point within a box
Please email me at <a href=mailto:candrsn at mindspring.com>candrsn at mindspring.com</a>
(Carl Anderson) with comments on this.
</pre>
</body>
</html>
More information about the grass-web mailing list
