[GRASSweb-list]markus: web grass_addons.html,1.28,1.29 grasscvstags.html,1.21,1.22 grassdevel.html,1.32,1.33
grass at intevation.de
Wed Nov 27 05:33:03 EST 2002
Author: markus
Update of /grassrepository/web
In directory doto:/tmp/cvs-serv25453
Modified Files:
grass_addons.html grasscvstags.html grassdevel.html
Log Message:
url fixes
Index: grass_addons.html
RCS file: /grassrepository/web/grass_addons.html,v
retrieving revision 1.28
retrieving revision 1.29
diff -u -d -r1.28 -r1.29
--- grass_addons.html 27 Nov 2002 09:05:09 -0000 1.28
+++ grass_addons.html 27 Nov 2002 10:33:01 -0000 1.29
@@ -37,7 +37,7 @@
GRASS shell extension</h2>
<ul>
-<li> <a href="http://www.buffalo.edu/~sorokine/complete/">GRASS shell
+<li> <a href="http://www.acsu.buffalo.edu/~sorokine/complete/">GRASS shell
completions for parameters and map names</a>: GRASS Complete allows you to
complete automatically correct arguments for GRASS commands when you press
'complete' key (usually <TAB>). It uses a 'complete' feature that is
Index: grasscvstags.html
RCS file: /grassrepository/web/grasscvstags.html,v
retrieving revision 1.21
retrieving revision 1.22
diff -u -d -r1.21 -r1.22
--- grasscvstags.html 27 Nov 2002 09:05:09 -0000 1.21
+++ grasscvstags.html 27 Nov 2002 10:33:01 -0000 1.22
@@ -20,7 +20,7 @@
<h2>GRASS GIS CVS repository Tags and Branches</h2>
Information about how to access our
-CVS repository you find <a href="grasscvs.html#4">here</a>.
+CVS repository you find <a href="grasscvs.html#access">here</a>.
<p>Tags in CVS indicate a development
state, a moment in time. Here you find a list of GRASS releases tagged in
CVS. If you want to download GRASS with defined status, you may use the "tags"
Index: grassdevel.html
RCS file: /grassrepository/web/grassdevel.html,v
retrieving revision 1.32
retrieving revision 1.33
diff -u -d -r1.32 -r1.33
--- grassdevel.html 27 Nov 2002 09:05:09 -0000 1.32
+++ grassdevel.html 27 Nov 2002 10:33:01 -0000 1.33
@@ -137,7 +137,7 @@
href=grass5/progmangrass50.pdf>PDF</a>, 2.3 MB, updated version 4/2002 |
<a href=http://mpa.itc.it/markus/grass50/>HTML</a> ]
<br>You can also access the latest Latex sources of the "GRASS 5.0
- Programmer's Manual" from our <a href="grasscvs.html#6">CVS server</a>.
+ Programmer's Manual" from our <a href="grasscvs.html#progman">CVS server</a>.
<li> <a href=demos/r.example.tar.gz>r.example: example C code for GRASS 5
raster programming</a>
</ul>
More information about the grass-web
