[GRASSweb-list]markus: web/grass51/source compilation_hints.html,NONE,1.1
grass at intevation.de grass at intevation.de
Tue Oct 15 04:05:15 EDT 2002
Author: markus
Update of /grassrepository/web/grass51/source
In directory doto:/tmp/cvs-serv16824
Added Files:
Log Message:
added hints for 5.0.0 compilation (POST_INSTALL.sh refers to it)
--- NEW FILE: compilation_hints.html ---
<HTML> <BODY BGCOLOR=#FFFFFF>
<h2>Some hints for GRASS 5.0.0 compilation problems</h2>
<pre>
Q. src/libes/edit/ does not compile:
A. Be sure to have libncurses5 and libncurses5-devel installed.
   There is a known problem with certain versions of gcc, particularly
   the one which is supplied with Mandrake 8.x, which results in the file
   src/libes/edit/edit_cellhd.c failing to compile.
   As a consequence further modules will not compile.
   The problem has been fixed in CVS (8/2002).
</pre>
Get this <a href=compilation_hints.html>file.</a>
<DIV ALIGN=right><i>
$Date: 2002/10/15 08:05:13 $
</i></DIV>
</HTML>
More information about the grass-web mailing list
