[GRASSweb-list]markus: web/faq termcap.html,NONE,1.1 index.html,1.6,1.7
grass at intevation.de grass at intevation.de
Fri Oct 25 03:59:26 EDT 2002
Author: markus
Update of /grassrepository/web/faq
In directory doto:/tmp/cvs-serv21277
Modified Files:
Added Files:
	termcap.html
Log Message:
added libtermcap question
--- NEW FILE: termcap.html ---
<html>
<title>GRASS and libtermcap problem</title>
<body bgcolor=#FFFFFF>
<b>Question:</b><p>
After the (successful?) installation of GRASS I get the following error
message:<br>
<pre>
Starting GRASS ...
/usr/local/grass5/etc/set_data: error while loading shared libraries:
   libtermcap.so.2: cannot open shared object file: No such file or directory
</pre>
What to do?<p>
<b>Answer:</b><p>
After the installation of the termcap library, GRASS will work.
<P>
SuSe Linux: the termcap library is located in package series [a]
<hr>
$Date: 2002/10/25 07:59:24 $<br>
<A HREF="index.html">Go back to GRASS FAQ...</A>
</body>
</html>
Index: index.html
RCS file: /grassrepository/web/faq/index.html,v
retrieving revision 1.6
retrieving revision 1.7
diff -u -d -r1.6 -r1.7
--- index.html	27 May 2002 08:07:57 -0000	1.6
+++ index.html	25 Oct 2002 07:59:24 -0000	1.7
@@ -20,12 +20,15 @@
 <td>
 <table BORDER=0 CELLSPACING=0 CELLPADDING=0 WIDTH="100%" BGCOLOR="#E6E6E6" >
 <tr>
-<td><a href="#general">Introduction</a> - <a href="#compile">Compiling</a>
-- <a href="#bugs">Bug Reports</a> -
-<a href="#docs">Documents</a> - <a href="#import">Import
-of data</a> -
-<a href="#problems">Problems and FAQ</a> - <a href="#archive">Mailing
-lists archives</a> - <a href="#nviz">NVIZ</a></td>
+<td><a href="#general">Introduction</a>
+- <a href="#compile">Compiling</a>
+- <a href="#bugs">Bug Reports</a>
+- <a href="#docs">Documents</a>
+- <a href="#import">Import of data</a>
+- <a href="#problems">Problems and FAQ</a>
+- <a href="#archive">Mailing lists archives</a>
+- <a href="#nviz">NVIZ</a>
+</td>
 </tr>
 </table>
 </td>
@@ -54,9 +57,11 @@
 <font face="Arial, Helvetica"><font size=+0><a href="../gdp/html_grass5/index.html">GRASS
 5.x Reference Manual</a></font></font></li>
 </ul>
 <a NAME="compile"></a><b><i><font face="Arial, Helvetica"><font size=+0>Compiling
 / Installation of GRASS:</font></font></i></b>
-<menu>
+<ul>
 <li>
 <font face="Arial, Helvetica"><font size=+0><a href="../download.html">Here</a>
 are the official GRASS releases</font></font></li>
@@ -67,35 +72,41 @@
 on here</a>.</font></font></li>
 <li>
-<font face="Arial, Helvetica"><font size=+0>Compiling GRASS:</font></font></li>
+<font face="Arial, Helvetica"><font size=+0>Installing GRASS:</font></font></li>
 <ul>
 <li>
-<font face="Arial, Helvetica"><font size=+0>Compilation terminates with
-this error: <a href="compile_on_linux.html">includes.h:7: X11/Xos.h No
-such file or directory</a>!</font></font></li>
+<font face="Arial, Helvetica"><font size=+0>When installing GRASS 5.x Linux
+binaries I get:<a href="termcap.html"> error while loading shared libraries:
+libtermcap !</a></font></font></li>
+<li>
+binaries I get:<a href="gislock_problem.html"> Unable to properly access
+/home/michele/.gislock5, Please notify to system personel!</a></font></font></li>
 <li>
-<font face="Arial, Helvetica"><font size=+0>I have developed or found a
-<a href="install_extra_modules.html">new
-extra module</a> for GRASS. How to compile it in GRASS environment?</font></font></li>
+<font face="Arial, Helvetica"><font size=+0>GRASS 4.x: Installation and
+<a href="lockdirectory.html">locks-directory</a>:
+I've a problem to understand what to do here.</font></font></li>
 </ul>
 <li>
-<font face="Arial, Helvetica"><font size=+0>Installing GRASS:</font></font></li>
+<font face="Arial, Helvetica"><font size=+0>Compiling GRASS:</font></font></li>
 <ul>
 <li>
-<font face="Arial, Helvetica"><font size=+0>When installing GRASS 5.x Linux
-binaries I get:<a href="gislock_problem.html"> Unable to properly access
-/home/michele/.gislock5, Please notify to system personel!</a></font></font></li>
+<font face="Arial, Helvetica"><font size=+0>Compilation terminates with
+this error: <a href="compile_on_linux.html">includes.h:7: X11/Xos.h No
+such file or directory</a>!</font></font></li>
 <li>
-<font face="Arial, Helvetica"><font size=+0>GRASS 4.x: Installation and
-<a href="lockdirectory.html">locks-directory</a>:
-I've a problem to understand what to do here.</font></font></li>
+<font face="Arial, Helvetica"><font size=+0>I have developed or found a
+<a href="install_extra_modules.html">new
+extra module</a> for GRASS. How to compile it in GRASS environment?</font></font></li>
 </ul>
 <li>
 <font face="Arial, Helvetica"><font size=+0>Installation of devices:</font></font></li>
@@ -113,7 +124,7 @@
 of <a href="http://www.relief.hu/index_5.html">digitizing boards</a> in
 GRASS/Linux.</font></font></li>
 </ul>
-</menu>
+</ul>
 <a NAME="bugs"></a><b><i><font face="Arial, Helvetica"><font size=+0>Reporting
 a bug?</font></font></i></b>
 <ul>
@@ -127,6 +138,7 @@
 <a href="../bugtracking/bugreport.html">GRASS
 GIS 5: Bug report System</a> to report.</font></font></li>
 </ul>
 <a NAME="docs"></a><b><i><font face="Arial, Helvetica"><font size=+0>Where
 is all the documentation?</font></font></i></b>
 <ul>
More information about the grass-web mailing list
