[GRASSweb-list]the excitement of http://grass.cis.sinica.edu.tw/grass51/
Markus Neteler
neteler at itc.it
Wed Oct 30 04:17:44 EST 2002
On Wed, Oct 30, 2002 at 09:08:53AM +0800, Dan Jacobson wrote:
> >>>>> "M" == Markus Neteler <neteler at itc.it> writes:
> M> On Sun, Oct 27, 2002 at 04:37:26PM +0800, Dan Jacobson wrote:
> >> Regarding all the excitement of
> >> Contrast it with the INSTALL file once we download the code:
> >> The GRASS 5.1 code repository currently contains only the new
> >> 3D/DBMS vector library and a few rewritten vector modules.
> >> Well, http://grass.cis.sinica.edu.tw/grass51/ should mention that.
> M> It does:
> M> "GRASS 5.1 project has been started. The current implementation covers the
> M> new 3D multiattribute, multilayer vector library, a modified NVIZ and a few
> M> database management tools."
> M> Or not?
> problem one, the items mentioned are not all the same.
> problem two, http://grass.cis.sinica.edu.tw/grass51/ should say
> "Only download 5.1 if you intend to use X, Y, Q... otherwise there is
> no need to upgrade from 5.0" or something like that.
ok, I have added a "status" description on top.
Markus Neteler
ITC-irst, Istituto per la Ricerca Scientifica e Tecnologica
Project on Predictive Models for the Environment
Via Sommarive, 18 - 38050 Povo (Trento), Italy
tel +39 0461 314 520 (fax -591) http://mpa.itc.it
More information about the grass-web
