[GRASSweb-list]markus: web/faq allocate_colorcell.html,1.1.1.1,1.2 already_running.html,1.1.1.1,1.2 arcgrid.header.html,1.1.1.1,1.2 celldriver.html,1.1.1.1,1.2 color_not_set.html,1.1.1.1,1.2 colors_weird.html,1.1.1.1,1.2 compile_grass.html,1.1.1.1,1.2 comp
grass at intevation.de grass at intevation.de
Wed Oct 30 06:14:20 EST 2002
Author: markus
Update of /grassrepository/web/faq
In directory doto:/tmp/cvs-serv19801/faq
Modified Files:
	allocate_colorcell.html already_running.html
	arcgrid.header.html celldriver.html color_not_set.html
	colors_weird.html compile_grass.html compile_on_linux.html
	cvs_howto.html d.3d_CELL.html digitizer_calcomp.html
	dxf_grass.html e00_import.html gislock_problem.html
	grass_coreldraw.html gtopo30_import.html
	importing_usgs_7_5min.html index.html
	install_extra_modules.html lockdirectory.html
	mailinglists_hints.html monitorsize.html ps_map_linux.html
	shape_import.html termcap.html xcolormap.html xy_to_utm.html
Log Message:
added new footers
Index: allocate_colorcell.html
RCS file: /grassrepository/web/faq/allocate_colorcell.html,v
retrieving revision 1.1.1.1
retrieving revision 1.2
diff -u -d -r1.1.1.1 -r1.2
--- allocate_colorcell.html	24 Nov 2001 18:28:00 -0000	1.1.1.1
+++ allocate_colorcell.html	30 Oct 2002 11:14:16 -0000	1.2
@@ -1,3 +1,4 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
 <html>
 <body bgcolor=#FFFFE0>
 <pre>
@@ -90,7 +91,6 @@
    desktop etc.). Use color reduced icons in this case.
 Markus Neteler
-neteler at itc.it
 July 1998
 </PRE>
 <hr>
Index: already_running.html
RCS file: /grassrepository/web/faq/already_running.html,v
--- already_running.html	24 Nov 2001 18:28:00 -0000	1.1.1.1
+++ already_running.html	30 Oct 2002 11:14:16 -0000	1.2
@@ -1,3 +1,4 @@
 <html>
 <pre>
@@ -34,7 +35,7 @@
 Now you can start a new GRASS monitor.
 <p>
-Markus Neteler   neteler at itc.it   Wed May 10 2000
+Markus Neteler     Wed May 10 2000
 </PRE>
 <hr>
 <A HREF="index.html">Go back to GRASS GIS FAQ...</A>
Index: arcgrid.header.html
RCS file: /grassrepository/web/faq/arcgrid.header.html,v
--- arcgrid.header.html	24 Nov 2001 18:28:00 -0000	1.1.1.1
+++ arcgrid.header.html	30 Oct 2002 11:14:16 -0000	1.2
@@ -1,3 +1,4 @@
 <html>
 <pre>
@@ -19,8 +20,7 @@
 this in the header before using r.in.ascii.
-Markus Neteler
-neteler at itc.it   Wed Jul 12 2000
+Markus Neteler      Wed Jul 12 2000
 </PRE>
 <hr>
Index: celldriver.html
RCS file: /grassrepository/web/faq/celldriver.html,v
--- celldriver.html	24 Nov 2001 18:28:00 -0000	1.1.1.1
+++ celldriver.html	30 Oct 2002 11:14:16 -0000	1.2
@@ -1,3 +1,4 @@
 <html>
 <pre>
@@ -84,7 +85,6 @@
 Markus Neteler
-neteler at itc.it
 20. Jan. 1999
 </PRE>
 <hr>
Index: color_not_set.html
RCS file: /grassrepository/web/faq/color_not_set.html,v
--- color_not_set.html	24 Nov 2001 18:28:00 -0000	1.1.1.1
+++ color_not_set.html	30 Oct 2002 11:14:16 -0000	1.2
@@ -1,3 +1,4 @@
 <html>
 <pre>
@@ -24,7 +25,7 @@
 video card. Read on <a href=allocate_colorcell.html>here</a> for
 setting color depth of XWindows server.
 <p>
-Markus Neteler   neteler at itc.it   10. Sept. 1999
+Markus Neteler   10. Sept. 1999
 </PRE>
 <hr>
Index: colors_weird.html
RCS file: /grassrepository/web/faq/colors_weird.html,v
--- colors_weird.html	24 Nov 2001 18:28:00 -0000	1.1.1.1
+++ colors_weird.html	30 Oct 2002 11:14:16 -0000	1.2
@@ -1,3 +1,4 @@
 <html>
 <head>
 <title>GRASS FAQ</title>
Index: compile_grass.html
RCS file: /grassrepository/web/faq/compile_grass.html,v
--- compile_grass.html	24 Nov 2001 18:28:00 -0000	1.1.1.1
+++ compile_grass.html	30 Oct 2002 11:14:16 -0000	1.2
@@ -1,6 +1,11 @@
+<html>
+<head>
 <title>GRASS compiling</title>
+</head>
- <strong>
+<strong>
 GRASS Compiling
 </strong><p>
@@ -17,7 +22,7 @@
 <HR>
 <em>Last Modified: 19th August 2000</em>
 <address>
-<A HREF="mailto:neteler at itc.it">Markus Neteler</A>
+<A HREF="mailto:weblist at grass.itc.it">Markus Neteler</A>
 </address>
 <HR>
Index: compile_on_linux.html
RCS file: /grassrepository/web/faq/compile_on_linux.html,v
retrieving revision 1.3
diff -u -d -r1.2 -r1.3
--- compile_on_linux.html	15 Mar 2002 12:45:28 -0000	1.2
+++ compile_on_linux.html	30 Oct 2002 11:14:16 -0000	1.3
@@ -1,4 +1,4 @@
-<!doctype html public "-//w3c//dtd html 4.0 transitional//en">
 <html>
 <head>
    <DEFANGED_meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
@@ -31,7 +31,7 @@
 existing in your Redhat distribution as well. Install this
 package and proceed with compilation.
 </pre>
-Markus Neteler neteler at itc.it Fri May 12 2000
+Markus Neteler  Fri May 12 2000
 <hr><a href="index.html">Go back to GRASS GIS FAQ...</a>
 </body>
 </html>
Index: cvs_howto.html
RCS file: /grassrepository/web/faq/cvs_howto.html,v
--- cvs_howto.html	15 Mar 2002 12:45:28 -0000	1.2
+++ cvs_howto.html	30 Oct 2002 11:14:16 -0000	1.3
@@ -1,4 +1,4 @@
 <html>
 <head>
@@ -81,7 +81,7 @@
 <hr></a><i>Last Modified: 3. Apr. 2001</i></font></font>
 <address>
-<font face="Arial, Helvetica"><font size=+0><a href="mailto:neteler at itc.it">Markus
+<font face="Arial, Helvetica"><font size=+0><a href="mailto:weblist at grass.itc.it">Markus
 Neteler</a></font></font></address>
 </body>
Index: d.3d_CELL.html
RCS file: /grassrepository/web/faq/d.3d_CELL.html,v
--- d.3d_CELL.html	24 Nov 2001 18:28:00 -0000	1.1.1.1
+++ d.3d_CELL.html	30 Oct 2002 11:14:16 -0000	1.2
@@ -1,3 +1,4 @@
 <html>
 <title>GRASS and 3D output</title>
@@ -64,7 +65,6 @@
 Markus Neteler/ Michel Wurtz
 9. September 1998
-neteler at itc.it
 </pre>
 </body>
 <hr>
Index: digitizer_calcomp.html
RCS file: /grassrepository/web/faq/digitizer_calcomp.html,v
--- digitizer_calcomp.html	24 Nov 2001 18:28:00 -0000	1.1.1.1
+++ digitizer_calcomp.html	30 Oct 2002 11:14:16 -0000	1.2
@@ -1,3 +1,4 @@
 <html>
 <pre>
Index: dxf_grass.html
RCS file: /grassrepository/web/faq/dxf_grass.html,v
--- dxf_grass.html	24 Nov 2001 18:28:00 -0000	1.1.1.1
+++ dxf_grass.html	30 Oct 2002 11:14:16 -0000	1.2
@@ -1,3 +1,4 @@
 <html>
 <title>GRASS and DXF</title>
Index: e00_import.html
RCS file: /grassrepository/web/faq/e00_import.html,v
--- e00_import.html	24 Nov 2001 18:28:00 -0000	1.1.1.1
+++ e00_import.html	30 Oct 2002 11:14:16 -0000	1.2
@@ -1,4 +1,4 @@
 <html>
 <head>
Index: gislock_problem.html
RCS file: /grassrepository/web/faq/gislock_problem.html,v
--- gislock_problem.html	24 Nov 2001 18:28:00 -0000	1.1.1.1
+++ gislock_problem.html	30 Oct 2002 11:14:16 -0000	1.2
@@ -51,7 +51,7 @@
 <A HREF="index.html">Back to GRASS GIS FAQ</A></DD>
 <ADDRESS>
-29. Feb. 2000 - <A HREF="mailto:neteler at itc.it">Markus Neteler</A></ADDRESS>
+29. Feb. 2000 - <A HREF="mailto:weblist at grass.itc.it">Markus Neteler</A></ADDRESS>
 </BODY>
 </HTML>
Index: grass_coreldraw.html
RCS file: /grassrepository/web/faq/grass_coreldraw.html,v
--- grass_coreldraw.html	24 Nov 2001 18:28:00 -0000	1.1.1.1
+++ grass_coreldraw.html	30 Oct 2002 11:14:16 -0000	1.2
@@ -1,3 +1,4 @@
 <html>
 <head>
 <title>GRASS GIS and CorelDraw</title>
@@ -22,7 +23,7 @@
 </menu>
 <p>
 <address>
-<a href=mailto:neteler at itc.it>Markus Neteler</a>
+<a href=mailto:weblist at grass.itc.it>Markus Neteler</a>
 Feb. 2000
 </address>
 <hr>
Index: gtopo30_import.html
RCS file: /grassrepository/web/faq/gtopo30_import.html,v
--- gtopo30_import.html	24 Nov 2001 18:28:00 -0000	1.1.1.1
+++ gtopo30_import.html	30 Oct 2002 11:14:16 -0000	1.2
@@ -1,5 +1,8 @@
+<html>
+<head>
 <title>Import of GTOPO30 data into GRASS</title>
+</head>
 <body bgcolor=#FFFFFF>
  <strong>
@@ -120,7 +123,7 @@
 <HR>
 <em>Last Modified: 25. Feb. 2000</em>
 <address>
-<A HREF="mailto:bouchard at onera.fr">Jacques Bouchard</A> / <A HREF="mailto:neteler at itc.it">Markus Neteler</A>
+<A HREF="mailto:bouchard at onera.fr">Jacques Bouchard</A> / <A HREF="mailto:weblist at grass.itc.it">Markus Neteler</A>
 </address>
Index: importing_usgs_7_5min.html
RCS file: /grassrepository/web/faq/importing_usgs_7_5min.html,v
--- importing_usgs_7_5min.html	24 Nov 2001 18:28:00 -0000	1.1.1.1
+++ importing_usgs_7_5min.html	30 Oct 2002 11:14:16 -0000	1.2
@@ -1,4 +1,5 @@
+<html>
 <title>Importing USGS 7.5min SDTS DEM into GRASS GIS</title>
  <strong>
@@ -378,3 +379,4 @@
 </address>
 </body>
+</html>
Index: index.html
RCS file: /grassrepository/web/faq/index.html,v
retrieving revision 1.8
retrieving revision 1.9
diff -u -d -r1.8 -r1.9
--- index.html	25 Oct 2002 08:00:58 -0000	1.8
+++ index.html	30 Oct 2002 11:14:16 -0000	1.9
@@ -1,4 +1,4 @@
 <html>
 <head>
@@ -326,7 +326,7 @@
 <hr><font face="Arial, Helvetica"><font size=+0><a href="../index2.html">Back
 to GRASS GIS pages</a></font></font>
 <address>
 </body>
Index: install_extra_modules.html
RCS file: /grassrepository/web/faq/install_extra_modules.html,v
--- install_extra_modules.html	15 Mar 2002 12:45:28 -0000	1.2
+++ install_extra_modules.html	30 Oct 2002 11:14:16 -0000	1.3
@@ -1,4 +1,4 @@
 <html>
 <head>
@@ -40,7 +40,7 @@
 <hr><a href="index.html">&nbsp;Back to GRASS FAQ pages</a>
 <address>
-<a href="mailto:neteler at itc.it">Markus Neteler</a></address>
+<a href="mailto:weblist at grass.itc.it">Markus Neteler</a></address>
 </body>
 </html>
Index: lockdirectory.html
RCS file: /grassrepository/web/faq/lockdirectory.html,v
--- lockdirectory.html	24 Nov 2001 18:28:00 -0000	1.1.1.1
+++ lockdirectory.html	30 Oct 2002 11:14:16 -0000	1.2
@@ -1,3 +1,4 @@
 <html>
 <pre>
@@ -37,7 +38,7 @@
  Ready. Now proceed with GRASS installation.
-Markus Neteler   neteler at itc.it   16th April 1999
+Markus Neteler      16th April 1999
 </PRE>
 <hr>
Index: mailinglists_hints.html
RCS file: /grassrepository/web/faq/mailinglists_hints.html,v
--- mailinglists_hints.html	24 Nov 2001 18:28:00 -0000	1.1.1.1
+++ mailinglists_hints.html	30 Oct 2002 11:14:16 -0000	1.2
@@ -1,3 +1,4 @@
 <HTML>
 <HEAD>
 <title>GRASS Mailing list hints</title>
@@ -54,7 +55,7 @@
 <HR>
 <em>Last Modified: 21. May 2001</em>
 <address>
 </address>
 </body>
 </html>
Index: monitorsize.html
RCS file: /grassrepository/web/faq/monitorsize.html,v
--- monitorsize.html	24 Nov 2001 18:28:00 -0000	1.1.1.1
+++ monitorsize.html	30 Oct 2002 11:14:16 -0000	1.2
@@ -1,3 +1,4 @@
 <html>
 <title>How to set the GRASS Monitor size in a script?</title>
@@ -27,7 +28,6 @@
 <address>
 Markus Neteler<br>
-neteler at itc.it<br>
 20. Jan. 2000<br>
 </address>
 <hr>
Index: ps_map_linux.html
RCS file: /grassrepository/web/faq/ps_map_linux.html,v
--- ps_map_linux.html	24 Nov 2001 18:28:00 -0000	1.1.1.1
+++ ps_map_linux.html	30 Oct 2002 11:14:16 -0000	1.2
@@ -1,3 +1,4 @@
 <html>
 <title>Compiling ps.map on Linux</title>
@@ -54,7 +55,7 @@
 <address>
 Markus Neteler <br>
 28. October 1998<br>
-<a href=mailto:neteler at itc.it>neteler at itc.it</a>
+<a href=mailto:weblist at grass.itc.it>neteler at itc.it</a>
 </address>
 <p>
 <a href="index.html">Go back to GRASS FAQ</a>
Index: shape_import.html
RCS file: /grassrepository/web/faq/shape_import.html,v
--- shape_import.html	24 Nov 2001 18:28:00 -0000	1.1.1.1
+++ shape_import.html	30 Oct 2002 11:14:16 -0000	1.2
@@ -1,10 +1,12 @@
+<html>
 <title>Import of ESRI SHAPE vector files into GRASS</title>
  <strong>
 </strong><p>
+[This applies to GRASS 5.0.x]<p>
 Currently there is only a "quick-and-dirty" way to import ESRI's vector
 shape files into GRASS GIS:
 <p>
@@ -60,10 +62,9 @@
 <HR>
 <em>Last Modified: 1st Nov. 1998</em>
 <address>
 </address>
 <HR>
 </body>
+</html>
\ No newline at end of file
Index: termcap.html
RCS file: /grassrepository/web/faq/termcap.html,v
--- termcap.html	26 Oct 2002 14:26:52 -0000	1.2
+++ termcap.html	30 Oct 2002 11:14:16 -0000	1.3
@@ -1,3 +1,4 @@
 <html>
 <title>GRASS and libtermcap problem</title>
Index: xcolormap.html
RCS file: /grassrepository/web/faq/xcolormap.html,v
--- xcolormap.html	24 Nov 2001 18:28:00 -0000	1.1.1.1
+++ xcolormap.html	30 Oct 2002 11:14:16 -0000	1.2
@@ -1,3 +1,4 @@
 <html>
 <pre>
@@ -37,7 +38,7 @@
  the GRASS monitors.
-Markus Neteler   neteler at itc.it   16th July 1998
+Markus Neteler    16th July 1998
 </PRE>
 <hr>
Index: xy_to_utm.html
RCS file: /grassrepository/web/faq/xy_to_utm.html,v
--- xy_to_utm.html	24 Nov 2001 18:28:00 -0000	1.1.1.1
+++ xy_to_utm.html	30 Oct 2002 11:14:16 -0000	1.2
@@ -1,3 +1,4 @@
 <html>
 <title>GRASS conversion xy-data to UTM</title>
More information about the grass-web mailing list
