[GRASSweb-list]markus: web grassdevel.html,1.18,1.19
grass at intevation.de grass at intevation.de
Fri Sep 6 04:35:45 EDT 2002
Author: markus
Update of /grassrepository/web
In directory doto:/tmp/cvs-serv9909
Modified Files:
	grassdevel.html
Log Message:
added SUBMITTING hint
Index: grassdevel.html
RCS file: /grassrepository/web/grassdevel.html,v
retrieving revision 1.18
retrieving revision 1.19
diff -u -d -r1.18 -r1.19
--- grassdevel.html	25 Jun 2002 14:13:25 -0000	1.18
+++ grassdevel.html	6 Sep 2002 08:35:42 -0000	1.19
@@ -142,6 +142,10 @@
 (which you find in the GRASS source code).
 <ul>
+<li> Code submission checklist: Please check your code against 'SUBMITTING'
+     file which you find in the main directory of the GRASS source code and
+     also <a href=grass5/source/SUBMITTING>here</a>. This ensures a smooth
+     integration into the standard GRASS code base.
 <li> Code submission: Please contact a member of the <A HREF=http://freegis.org/cgi-bin/viewcvs.cgi/~checkout~/grass/AUTHORS>GRASS Development Team</a>
      or write to the development mailing list (see <A HREF="#list">above</a>).
 <li> GRASS Add-on submission: <a href=grass_addons.html>go here</a> (Add-on code
More information about the grass-web mailing list
