[GRASSweb-list]bernhard: web/bugtracking bugreport.html,1.16,1.17
grass at intevation.de grass at intevation.de
Fri Sep 6 10:17:23 EDT 2002
Author: bernhard
Update of /grassrepository/web/bugtracking
In directory doto:/tmp/cvs-serv15943
Modified Files:
	bugreport.html
Log Message:
Fixed: Current released version is 5.0.0.
Index: bugreport.html
RCS file: /grassrepository/web/bugtracking/bugreport.html,v
retrieving revision 1.16
retrieving revision 1.17
diff -u -d -r1.16 -r1.17
--- bugreport.html	25 Jun 2002 16:57:16 -0000	1.16
+++ bugreport.html	6 Sep 2002 14:17:21 -0000	1.17
@@ -17,8 +17,9 @@
 of the bug or request.
 <p>
 <ul>
-<li> Only report if using GRASS 5 pre4 (released 13 May 2002) or later
-version. If you use an older GRASS 5.0 release, please consider to <a
+<li> Only report if using at least the current stable release version
+(GRASS 5.0.0 was released 2nd September 2002).
+If you use an older version, please consider to <a
 href=../download.html>upgrade</a>.
 <li> Before reporting a bug, please check that it is currently unkown:
More information about the grass-web mailing list
