[GRASSweb-list]moritz: web/grass5/source README.html,1.5,1.6
grass at intevation.de
Sat Sep 21 08:23:06 EDT 2002
Author: moritz
Update of /grassrepository/web/grass5/source
In directory doto:/tmp/cvs-serv7349
Modified Files:
README.html
Log Message:
erased references to preX, to leave grass5.0.0
Index: README.html
RCS file: /grassrepository/web/grass5/source/README.html,v
retrieving revision 1.5
retrieving revision 1.6
diff -u -d -r1.5 -r1.6
--- README.html 9 Aug 2002 07:56:01 -0000 1.5
+++ README.html 21 Sep 2002 12:23:04 -0000 1.6
@@ -1,9 +1,9 @@
<HTML> <BODY BGCOLOR=#FFFFFF>
<pre>
This directory contains the source code for
-GRASS GIS 5.0.0 (prerelease X) in gzipped tar format.
+GRASS GIS 5.0.0 in gzipped tar format.
-The large (25 MB) file grass5.0.0preX_src.tar.gz is the
+The large (25 MB) file grass5.0.0_src.tar.gz is the
officially released GRASS 5.0 source code in a single file.
Also here: weekly generated CVS snapshots
@@ -25,13 +25,13 @@
- Put the package there and extract it (replace "X" with
the current version number of GRASS 5.0.0preX):
- gunzip grass5.0.0preX.tar.gz
- tar -xvf grass5.0.0preX.tar
+ gunzip grass5.0.0.tar.gz
+ tar -xvf grass5.0.0.tar
Example:
- gunzip grass5.0.0pre1.tar.gz
- tar -xvf grass5.0.0pre1.tar
This will create the necessary directories and
files for you to compile GRASS.
@@ -44,9 +44,9 @@
A) If you have "root" access to your machine:
- Jump into the new directory "grass5.0.0preX" (change X to the current
+ Jump into the new directory "grass5.0.0" (change X to the current
release number):
- cd grass5.0.0preX
+ cd grass5.0.0
To compile enter following:
@@ -60,10 +60,10 @@
B) If you have no "root" access: You can also compile
GRASS locally (replace "user" with your username):
release number):
- cd grass5.0.0preX
+ cd grass5.0.0
Then start the process:
More information about the grass-web
