[GRASSweb-list]markus: web grasscvstags.html,1.7,1.8
grass at intevation.de
Sun Sep 22 20:36:56 EDT 2002
Author: markus
Update of /grassrepository/web
In directory doto:/tmp/cvs-serv12697
Modified Files:
grasscvstags.html
Log Message:
further fixes branches and tags
Index: grasscvstags.html
RCS file: /grassrepository/web/grasscvstags.html,v
retrieving revision 1.7
retrieving revision 1.8
diff -u -d -r1.7 -r1.8
--- grasscvstags.html 23 Sep 2002 00:33:17 -0000 1.7
+++ grasscvstags.html 23 Sep 2002 00:36:54 -0000 1.8
@@ -43,42 +43,37 @@
<p>
<table BORDER BGCOLOR="#FFFFCC" NOSAVE >
<tr NOSAVE>
-<td NOSAVE><font face="Arial, Helvetica"><font size=+0>To check out the
-lastest unstable code into a fresh directory, enter: </font></font>
-<br><font face="Arial, Helvetica"><font size=+0>
- cvs -z3 checkout grass
-</font></font>
-</td></tr>
-<tr NOSAVE>
To update your existing <b>experimental</b> CVS tree to the <b>stable release
branch</b> instead of downloading a full copy, enter:<br>
- cvs update -r <br>
- cvs up -dP release_30_08_2002_grass5_0_0
+ cvs update -r release_30_08_2002_grass5_0_0<br>
+ cvs up -dP
</font></font>
</td>
</tr>
</table>
-<li>
-GRASS 5.0.0: On 5 September 2002, the GRASS 5.0.0 stable was created with a tag name
-of "release_30_08_2002_grass5_0_0".
-<li>
-Below tags are ONLY used to define a specific state in GRASS development.
-If you want to get the latest stable GRASS 5 code, use above tag.
+<li>GRASS 5.0.0 experimental (HEAD):
+<p>
+<table BORDER BGCOLOR="#FFFFCC" NOSAVE >
+<tr NOSAVE>
+<td NOSAVE><font face="Arial, Helvetica"><font size=+0>To check out the
+lastest unstable code into a fresh directory, enter: </font></font>
+<br><font face="Arial, Helvetica"><font size=+0>
+ cvs -z3 checkout grass
+</font></font>
+</td></tr>
+</table>
+</ul>
+<FONT FACE="Arial, Helvetica" size="3">
+<h2>Experimental: CVS tags in GRASS </b> (outdated, but present in CVS) </h2>
<ul>
<li>GRASS 5.0.0pre5: has been tagged as "release_25_06_2002_grass5_0_0_pre5"
<li>GRASS 5.0.0pre4: has been tagged as "release_13_may_2002_grass5_0_0_pre4"
<li>GRASS 5.0.0pre3: has been tagged as "release_16_january_2002_grass5_0_0_pre3"
<li>GRASS 5.0.0pre2: has been tagged as "release_13_september_2001_grass5_0_0_pre2"
<li>GRASS 5.0.0pre1: has been tagged as "release_grass500pre1_20_may_2001"
-</ul>
-</ul>
-<FONT FACE="Arial, Helvetica" size="3">
-<h2>Experimental: CVS tags in GRASS </b> (outdated, but present in CVS) </h2>
-Note: since beta 11 we are working on above release branch.
-<ul>
<li>GRASS 5 beta 11: has been tagged as "release_grass5beta11_4_february_2001"
<li>GRASS 5 beta 10: has been tagged as "release_grass5beta10_7_december_2000"
<li>GRASS 5 beta 9: has been tagged as "release_grass5beta9_6_december_2000"
More information about the grass-web
