[GRASSweb-list]markus: web grasscvstags.html,1.9,1.10
grass at intevation.de
Mon Sep 23 12:37:02 EDT 2002
- Previous message: [GRASSweb-list]markus: web codemanagement.html,1.5,1.6 data.html,1.13,1.14 download.html,1.30,1.31 grasscvs.html,1.12,1.13 grasscvscommit.html,1.4,1.5 grassdevel.html,1.19,1.20 index.html,1.21,1.22 links.html,1.6,1.7 modelintegration.html,1.5,1.6 newsarchi
- Next message: [GRASSweb-list]markus: web newsarchive.html,1.8,1.9 press.html,1.9,1.10
- Messages sorted by:
[ date ]
[ thread ]
[ subject ]
[ author ]
Author: markus
Update of /grassrepository/web
In directory doto:/tmp/cvs-serv28877
Modified Files:
grasscvstags.html
Log Message:
cosmetics
Index: grasscvstags.html
RCS file: /grassrepository/web/grasscvstags.html,v
retrieving revision 1.9
retrieving revision 1.10
diff -u -d -r1.9 -r1.10
--- grasscvstags.html 23 Sep 2002 00:42:32 -0000 1.9
+++ grasscvstags.html 23 Sep 2002 16:37:00 -0000 1.10
@@ -1,101 +1,138 @@
+<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
- <DEFANGED_meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
- <title>List of GRASS GIS CVS repository Tags</title>
+ <DEFANGED_meta http-equiv="Content-Type"
+ content="text/html; charset=iso-8859-1">
+ <title>List of GRASS GIS CVS repository Tags</title>
</head>
-<body text="#000000" bgcolor="#FFFFFF">
-<FONT FACE="Arial, Helvetica" size="3">
-<h2>CVS, tags, branches and the GRASS development cycle</h2>
-Most of the time, GRASS development occurs at the head of the CVS
-tree. When the code becomes sufficiently stable that it could be
-considered a candidate for release, a branch is created in CVS. This
-branch may be checked out using the appropriate CVS tag.
-<p>
-When the branch is created the release is considered "frozen". That
-is, no new features will be added to that branch, but only fixes for
-bugs. As fixes are applied to the branch, they will also be merged
-into the head of the tree, where other experimental development will
-continue. After a period of testing and bug fixing, the release branch
-will be considered stable and officially released.
-<h2>GRASS GIS CVS repository Tags and Branches</h2>
-Information about how to access the CVS repository you find <a
-href=grasscvs.html#4>here</a>.<p>
-<p>
-Tags in CVS indicate a development state, a moment in time. Here you find a
-list of GRASS releases tagged in CVS. If you want to download GRASS with
-defined status, you may use the "tags" denoted here:
-<h2>GRASS 5.0.0 stable branch:</h2>
+<body text="#000000" bgcolor="#ffffff">
+<font face="Arial, Helvetica" size="3"></font>
+<h2><font face="Arial, Helvetica" size="3">CVS, tags, branches and the GRASS
+development cycle</font></h2>
+<font face="Arial, Helvetica" size="3">Most of the time, GRASS development
+occurs at the head of the CVS tree. When the code becomes sufficiently stable
+that it could be considered a candidate for release, a branch is created
+in CVS. This branch may be checked out using the appropriate CVS tag. </font><br>
+<font face="Arial, Helvetica" size="3"> When the branch is created the release
+is considered "frozen". That is, no new features will be added to that branch,
+but only fixes for bugs. As fixes are applied to the branch, they will also
+be merged into the head of the tree, where other experimental development
+will continue. After a period of testing and bug fixing, the release branch
+will be considered stable and officially released. </font><br>
+<font face="Arial, Helvetica" size="3">GRASS GIS CVS repository Tags and
+Branches</font><br>
+<font face="Arial, Helvetica" size="3">Information about how to access the
+CVS repository you find <a href="grasscvs.html#4">here</a>.</font>
+<p></p>
+<p><font face="Arial, Helvetica" size="3">Tags in CVS indicate a development
+state, a moment in time. Here you find a list of GRASS releases tagged in
+CVS. If you want to download GRASS with defined status, you may use the "tags"
+denoted here: </font></p>
+<h3><font face="Arial, Helvetica" size="3">GRASS 5.0.0 stable branch:</font></h3>
<center>
-<table BORDER BGCOLOR="#FFFFCC" NOSAVE >
-<tr NOSAVE>
-<td NOSAVE><font face="Arial, Helvetica"><font size=+0>
-To update your existing <b>experimental</b> CVS tree to the <b>stable release
-branch</b> instead of downloading a full copy, enter:<br>
+<table border="1" bgcolor="#ffffcc" nosave="">
+ <tbody>
+ <tr nosave="">
+ <td nosave=""><font face="Arial, Helvetica"><font size="+0">To update
+your existing <b>experimental</b> CVS tree to the <b>stable release branch</b>
+instead of downloading a full copy, enter:<br>
cvs update -r release_30_08_2002_grass5_0_0<br>
- cvs up -dP
-</font></font>
-</td>
-</tr>
+ cvs up -dP</font></font></td>
+ </tr>
+ </tbody>
</table>
</center>
-<FONT FACE="Arial, Helvetica">
-<h2>Experimental (HEAD):</h2>
+<font face="Arial, Helvetica" size="3"><font face="Arial, Helvetica"></font></font>
+<h3><br>
+</h3>
+<h3><font face="Arial, Helvetica" size="3"><font face="Arial, Helvetica">GRASS
+5.0.0 Experimental (HEAD):</font></font></h3>
<center>
-<tr NOSAVE>
-<td NOSAVE><font face="Arial, Helvetica"><font size=+0>To check out the
-lastest unstable code into a fresh directory, enter: </font></font>
-<br><font face="Arial, Helvetica"><font size=+0>
- cvs -z3 checkout grass
-</font></font>
-</td></tr>
+ <tbody>
+ <tr nosave="">
+ <td nosave=""><font face="Arial, Helvetica"><font size="+0">To check
+out the lastest unstable 5.0 code into a fresh directory, enter: </font></font>
+ <br>
+ <font face="Arial, Helvetica"><font size="+0"> cvs -z3 checkout
+grass</font></font></td>
+ </tr>
+ </tbody>
</table>
</center>
-<b>Outdated CVS tags in GRASS </b> (outdated, but present in CVS)
-<p>
+<br>
+<p></p>
<ul>
-<li>GRASS 5.0.0pre5: has been tagged as "release_25_06_2002_grass5_0_0_pre5"
-<li>GRASS 5.0.0pre4: has been tagged as "release_13_may_2002_grass5_0_0_pre4"
-<li>GRASS 5.0.0pre3: has been tagged as "release_16_january_2002_grass5_0_0_pre3"
-<li>GRASS 5.0.0pre2: has been tagged as "release_13_september_2001_grass5_0_0_pre2"
-<li>GRASS 5.0.0pre1: has been tagged as "release_grass500pre1_20_may_2001"
-<li>GRASS 5 beta 11: has been tagged as "release_grass5beta11_4_february_2001"
-<li>GRASS 5 beta 10: has been tagged as "release_grass5beta10_7_december_2000"
-<li>GRASS 5 beta 9: has been tagged as "release_grass5beta9_6_december_2000"
-<li>GRASS 5 beta 8: has been tagged as "release_grass5beta8_26_july_2000"
-<li>GRASS 5 beta 7: has been tagged as "release_grass5beta7_20_april_2000"
-<li>GRASS 5 beta 6: has been tagged as "release_grass5beta6_16_feb_2000"
+ <li><font face="Arial, Helvetica" size="3"><font
+ face="Arial, Helvetica"><b>Outdated CVS tags in GRASS </b> (outdated, but
+present in CVS): </font></font></li>
+ <ul>
+ face="Arial, Helvetica">GRASS 5.0.0pre5: has been tagged as "release_25_06_2002_grass5_0_0_pre5"</font></font></li>
+ face="Arial, Helvetica">GRASS 5.0.0pre4: has been tagged as "release_13_may_2002_grass5_0_0_pre4"
+ </font></font></li>
+ face="Arial, Helvetica">GRASS 5.0.0pre3: has been tagged as "release_16_january_2002_grass5_0_0_pre3"
+ face="Arial, Helvetica">GRASS 5.0.0pre2: has been tagged as "release_13_september_2001_grass5_0_0_pre2"
+ face="Arial, Helvetica">GRASS 5.0.0pre1: has been tagged as "release_grass500pre1_20_may_2001"
+ face="Arial, Helvetica">GRASS 5 beta 11: has been tagged as "release_grass5beta11_4_february_2001"
+ face="Arial, Helvetica">GRASS 5 beta 10: has been tagged as "release_grass5beta10_7_december_2000"
+ face="Arial, Helvetica">GRASS 5 beta 9: has been tagged as "release_grass5beta9_6_december_2000"
+ face="Arial, Helvetica">GRASS 5 beta 8: has been tagged as "release_grass5beta8_26_july_2000"
+ face="Arial, Helvetica">GRASS 5 beta 7: has been tagged as "release_grass5beta7_20_april_2000"
+ face="Arial, Helvetica">GRASS 5 beta 6: has been tagged as "release_grass5beta6_16_feb_2000</font></font></li>
+ </ul>
</ul>
-<h2>Experimental: GRASS 5.1 CVS tags</b></h2>
-No tag so far, but you can check out the code by:
+<br>
+<font face="Arial, Helvetica" size="3"><font face="Arial, Helvetica"><font
+ face="Arial, Helvetica" size="3"></font></font></font>
+<h3><font face="Arial, Helvetica" size="3"><font face="Arial, Helvetica"><font
+ face="Arial, Helvetica" size="3">GRASS 5.1 Experimental: CVS tags</font></font></font></h3>
+ face="Arial, Helvetica" size="3">No tag so far, but you can check out the
+code with:<br>
+<br>
+</font></font></font>
+<center>
+ <tbody>
+ <tr nosave="">
+out the lastest unstable 5.1 code into a fresh directory, enter: </font></font>
+ <br>
+grass51</font></font></td>
+ </tr>
+ </tbody>
+</table>
+</center>
<ul>
-<li><tt>cvs -z3 co grass51</tt>
</ul>
<hr>
-<center>
-<font face="Arial, Helvetica"><font color="#000000"><font size=-2>
-<a href="index2.html">
-<DEFANGED_IMG SRC="images/gbanner_small.jpg" BORDER=0></a>
-<br>
+<center><font face="Arial, Helvetica" size="3"><font
+ face="Arial, Helvetica"><font face="Arial, Helvetica" size="3"><font
+ face="Arial, Helvetica"><font color="#000000"><font size="-2"><a
+ href="index2.html"><DEFANGED_IMG src="images/gbanner_small.jpg" border="0"></a><br>
Send your GRASS-CVS related <a href="mailto:weblist at grass.itc.it">email</a>
-</center>
+</font></font></font></font></font></font></center>
+<br>
</body>
</html>
[ date ]
[ thread ]
[ subject ]
[ author ]
More information about the grass-web
