[GRASSweb-list]radim: web/sqlgrass odbc_grass_install.html,1.8,1.9
    grass at intevation.de
    Mon Apr  7 03:34:48 EDT 2003
Author: radim
Update of /grassrepository/web/sqlgrass
In directory doto:/tmp/cvs-serv28332
Modified Files:
Log Message:
driver/db/
Index: odbc_grass_install.html
RCS file: /grassrepository/web/sqlgrass/odbc_grass_install.html,v
retrieving revision 1.8
retrieving revision 1.9
diff -u -d -r1.8 -r1.9
--- odbc_grass_install.html	10 Nov 2002 00:37:02 -0000	1.8
+++ odbc_grass_install.html	7 Apr 2003 07:34:46 -0000	1.9
@@ -38,7 +38,7 @@
 for the database you have chosen. However it is not necessary we recommend
 to install GUI configuration tools for ODBC: ODBCConfig and DataManager
 (unixODBC-kde rpm in RH distribution). Finaly you need GRASS-to-odbc-driver.
-Check if this driver exists: $GISBASE/driver/odbc. If this driver is not
+Check if this driver exists: $GISBASE/driver/db/odbc. If this driver is not
 available you must compile grass/src/libes/dbmi/drivers/odbc/ (<a href="../download.html">GRASS
 source code</a>).</li>
More information about the grass-web
