[GRASSweb-list]markus: web/bugtracking bugreport.html,1.24,1.25
    grass at intevation.de
    Fri Apr 11 03:35:35 EDT 2003
Author: markus
Update of /grassrepository/web/bugtracking
In directory doto:/tmp/cvs-serv28632/bugtracking
Modified Files:
	bugreport.html
Log Message:
5.0.2 released
Index: bugreport.html
RCS file: /grassrepository/web/bugtracking/bugreport.html,v
retrieving revision 1.24
retrieving revision 1.25
diff -u -d -r1.24 -r1.25
--- bugreport.html	22 Jan 2003 09:58:31 -0000	1.24
+++ bugreport.html	11 Apr 2003 07:35:33 -0000	1.25
@@ -20,9 +20,8 @@
 <p>
 <ul>
 <li> Only report if using at least the current stable release version
-(GRASS 5.0.0 was released 2nd September 2002).
-If you use an older version, please consider to <a
-href=../download.html>upgrade</a>.
+(GRASS 5.0.2 was released 10 April 2003).
+If you use an older version, please consider to <a href=../download.html>upgrade</a>.
 <li> Before reporting a bug, please check that it is currently unkown:
 <br>
More information about the grass-web
