[GRASSweb-list]markus: web index.html,1.46,1.47
grass at intevation.de grass at intevation.de
Fri Apr 18 11:23:25 EDT 2003
Author: markus
Update of /grassrepository/web
In directory doto:/tmp/cvs-serv31101
Modified Files:
Log Message:
MPA group -> MPBA group
Index: index.html
RCS file: /grassrepository/web/index.html,v
retrieving revision 1.46
retrieving revision 1.47
diff -u -d -r1.46 -r1.47
--- index.html	16 Apr 2003 15:26:30 -0000	1.46
+++ index.html	18 Apr 2003 15:23:23 -0000	1.47
@@ -179,10 +179,10 @@
 GRASS is developed by a worldwide network of developers who continue to
 release new GRASS versions regularly. The main web site, the GRASS
 development mailing list and further lists are hosted at <a
-href="http://www.itc.it">ITC-irst</a> in Italy (SSI/<a
-href="http://mpa.itc.it">MPA group</a>). The source code is maintained in a
+href="http://www.itc.it/">ITC-irst</a> in Italy (SSI/<a
+href="http://mpa.itc.it/">MPBA group</a>). The source code is maintained in a
 CVS server which is run along with the bug tracker by <a
-href="http://www.intevation.net">Intevation GmbH</a> in Germany. The GRASS user
+href="http://www.intevation.net/">Intevation GmbH</a> in Germany. The GRASS user
 list is hosted at Baylor University, USA (<a
 href="http://www3.baylor.edu/cagsr/">CAGSR</a>). Finally we are supported by
 numerous <a href="grass.mirrors.html">mirror sites</a>.
More information about the grass-web mailing list
