[GRASSweb-list]markus: web/grass51/tutorial network.html,1.8,1.9
grass at intevation.de grass at intevation.de
Wed Aug 13 12:22:04 EDT 2003
Author: markus
Update of /grassrepository/web/grass51/tutorial
In directory doto:/tmp/cvs-serv5605
Modified Files:
	network.html
Log Message:
v.distance.connect -> v.distance
Index: network.html
RCS file: /grassrepository/web/grass51/tutorial/network.html,v
retrieving revision 1.8
retrieving revision 1.9
diff -u -d -r1.8 -r1.9
--- network.html	13 Aug 2003 16:06:09 -0000	1.8
+++ network.html	13 Aug 2003 16:22:01 -0000	1.9
@@ -262,7 +262,8 @@
 First we generate the connection map between schools and closest streets:
 <div class="code"><pre>
-v.distance.connect input1=schools input2=strassen output=streets_schools_connect
+v.distance -p from=schools to=strassen output=streets_schools_connect upload=dist column=dist
 d.erase
 d.vect strassen col=grey
 d.vect schools col=red
More information about the grass-web mailing list
