[GRASSweb-list]markus: web/tcltkgrass index.html,1.1,1.2
grass at intevation.de grass at intevation.de
Sat Dec 13 11:22:56 EST 2003
Author: markus
Update of /grassrepository/web/tcltkgrass
In directory doto:/tmp/cvs-serv22716
Modified Files:
Log Message:
removed outdated requirements section
Index: index.html
RCS file: /grassrepository/web/tcltkgrass/index.html,v
retrieving revision 1.1
retrieving revision 1.2
diff -u -d -r1.1 -r1.2
--- index.html	22 Apr 2003 16:06:52 -0000	1.1
+++ index.html	13 Dec 2003 16:22:54 -0000	1.2
@@ -77,54 +77,8 @@
 instructions</a>:</b> Create your own extensions to this GRASS user interface.
 <p>
 <hr>
-<h2>
-Requirements</h2>
-The current version of TclTkGRASS is free of binary code. So it is usable
-on each flavor of unix - TclTkGRASS is platform indepentent! Required are
-the <b>TCL/TK 8.0 graphical libraries</b>. They will create all the buttons
-etc you see in the screenshot above. Check you computer if "wish8.0" is
-installed. If you find only "wish4.2" then you must install these 8.0 library
-version. You can simply compile them yourself, the package owns a configuration
-routine for your compiler. In the TclTkGRASS packages below you find the
-library compiling instructions. If you already have "wish8.0", feel happy
-- no more work! The source code for these Tcl/TK 8.0 library you find
-<a href="http://www.scriptics.com/products/tcltk/">here</a>
-(you must get the <i>unix sources</i> there!). If you are using Linux,
-SUN Solaris or SGI/Irix, you can also get the precompiled library-files
-here.
-<br>Check your computer for graphical libraries already being installed
-with:
-<p><i>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; <tt>which wish8.0</tt></i>
-<p>If they are not installed, you may get the precompiled libraries depending
-on your platform or the source code:<b></b>
-<p><b>Tcl/Tk 8.0.5 source code:</b>
-<dl>
-<ul>
-<li>
-<a href="libraries/tcl8.0.5.tar.gz">TCL
-8.0.5 source code</a> and <a href="libraries/tk8.0.5.tar.gz">TK
-8.0.5 source code</a> with <a href="libraries/INST_tcltk_libs_source.txt">compile
-instructions</a></li>
-<li>
-Original <a href="http://www.scriptics.com/products/tcltk/">Tcl/tk library
-site</a></li>
-</ul>
-</dl>
-<b>Precompiled binaries:</b>
-<menu>
-<li>
-Linux/Intel: <a href="libraries/tcltk8.0.5_libs_linux.tar.gz">tcltk8.0.5
-libraries</a>. Installation: Unpack package in / (root directory) - <a href="libraries/README_tcltk80_libs.txt">full
-instructions</a>.</li>
-<li>
-Solaris2.6/SUN: <a href="libraries/tcltk8.0.5_libs_solaris26.tar.gz">tcltk8.0.5
-</menu>
-<hr><a href="welcome.html">Back to GRASS GIS pages</a>
+<hr><a href="../index.html">Back to GRASS GIS pages</a>
 <address>
 (c) 1998-2000 by Markus Neteler</address>
More information about the grass-web mailing list
