[GRASSweb-list]markus: web/grass51/tutorial index.html,1.11,1.12
grass at intevation.de
Mon Feb 10 12:34:31 EST 2003
- Previous message: [GRASSweb-list]markus: web/grass51/tutorial techdocs.html,NONE,1.1 attrib_storage.html,1.11,1.12 demo.html,1.5,1.6 examples.html,1.15,1.16 geom_storage.html,1.8,1.9 index.html,1.10,1.11 troubleshooting.html,1.1,1.2
- Next message: [GRASSweb-list]markus: web firsttime.html,1.25,1.26
- Messages sorted by:
[ date ]
[ thread ]
[ subject ]
[ author ]
Author: markus
Update of /grassrepository/web/grass51/tutorial
In directory doto:/tmp/cvs-serv23931
Modified Files:
Log Message:
v.database
Index: index.html
RCS file: /grassrepository/web/grass51/tutorial/index.html,v
retrieving revision 1.11
retrieving revision 1.12
diff -u -d -r1.11 -r1.12
--- index.html 10 Feb 2003 17:32:26 -0000 1.11
+++ index.html 10 Feb 2003 17:34:29 -0000 1.12
@@ -35,15 +35,18 @@
Per default all GRASS 5.1 vectors are stored in native 5.1 format within the
directory $GISDBASE/$LOCATION_NAME/$MAPSET/vector/$MAP/. All map related
data such as geometry data, spatial index, DB-connection info etc. are
-stored in this directory (see <i>Geometry management</i> below for details).
+stored in this directory. The default settings (DBMI driver and DATABASE)
+can be modified with 'v.database'.
+See <i>Geometry management</i> below for details.
<P>
<b>Default settings for vector attributes</b><P>
Per default all GRASS 5.1 vector attributes are stored in a DBF table within
the directory $GISDBASE/$LOCATION_NAME/$MAPSET/dbf. The default settings
-(DBMI driver and DATABASE) can be modified with 'db.connect' (see
-<i>Attribute management</i> below for details).
+(DBMI driver and DATABASE) can be modified with 'v.database' (for the vector
+modules) and 'db.connect' (for the db.* modules).
+See <i>Attribute management</i> below for details.
<h2>GRASS 5.1 Tutorial</h2>
[ date ]
[ thread ]
[ subject ]
[ author ]
More information about the grass-web
