[GRASSweb-list]markus: web/statsgrass grass_r_insthints.html,1.11,1.12
grass at intevation.de
Thu Feb 20 04:49:45 EST 2003
Author: markus
Update of /grassrepository/web/statsgrass
In directory doto:/tmp/cvs-serv27786
Modified Files:
Log Message:
simplified new installation, thanks to Roger Bivand
Index: grass_r_insthints.html
RCS file: /grassrepository/web/statsgrass/grass_r_insthints.html,v
retrieving revision 1.11
retrieving revision 1.12
diff -u -d -r1.11 -r1.12
--- grass_r_insthints.html 19 Dec 2002 18:50:46 -0000 1.11
+++ grass_r_insthints.html 20 Feb 2003 09:49:43 -0000 1.12
@@ -26,6 +26,26 @@
</pre>
<hr>
+From version 0.2-3, the regular R package install mechanisms will work,
+including the online installation of the source package under
+<b>Linux/Unix</b>:
+<pre>
+> install.packages("GRASS")
+</pre>
+<P>
+For <B>MS-Windows binary online installation</b>, either download GRASS.zip
+from <a href=http://spatial.nhh.no/R/GRASS/>http://spatial.nhh.no/R/GRASS/</a>,
+or wait for Prof. Brian Ripley's build train to make the package available on
+CRAN.<P>
+The notes below refer to manual installation and linking with GRASS
+libraries in versions up to and including 0.2-1.
+<hr>
+<h1>Older versions: Installation of GRASS/R interface versions < 0.2-3 </h1>
<h2>A) Installation on UN*X compilant systems (Linux etc)</h2>
<pre>
@@ -105,17 +125,13 @@
NOTE 3: We also succeeded to run R in GRASS on Cygwin in batch mode.
-<hr>
-Future: Once the GRASS/R interface reaches the standard contrib space on the R web
-site, the options() command and install.packages() will work and simplify
-the installation.
</pre>
(You are kindly invited to improve this page as send it to us)
<!-- FOOTER -->
<hr>
-<DIV ALIGN=right>© 2001-2002 GRASS Development Team<br>
+<DIV ALIGN=right>© 2001-2003 GRASS Development Team<br>
<a href="mailto:weblist at grass.itc.it">Comments</a> about this page | Back <a href=../index.html>HOME</a><br>
<i>Last change:
$Date$
More information about the grass-web
