[GRASSweb-list]markus: web/grass51/tutorial attrib_storage.html,1.14,1.15 demo.html,1.7,1.8 ex_basic.html,1.3,1.4 ex_complex.html,1.3,1.4 examples.html,1.20,1.21 geom_storage.html,1.11,1.12 index.html,1.14,1.15 intro.html,1.2,1.3 links.html,1.3,1.4 techdoc
grass at intevation.de grass at intevation.de
Fri Feb 28 15:00:07 EST 2003
Author: markus
Update of /grassrepository/web/grass51/tutorial
In directory doto:/tmp/cvs-serv20807
Modified Files:
	attrib_storage.html demo.html ex_basic.html ex_complex.html
	examples.html geom_storage.html index.html intro.html
	links.html techdocs.html troubleshooting.html
Log Message:
v.format, v.databse explained, cleanup
Index: attrib_storage.html
RCS file: /grassrepository/web/grass51/tutorial/attrib_storage.html,v
retrieving revision 1.14
retrieving revision 1.15
diff -u -d -r1.14 -r1.15
--- attrib_storage.html	20 Feb 2003 16:42:14 -0000	1.14
+++ attrib_storage.html	28 Feb 2003 20:00:04 -0000	1.15
@@ -19,10 +19,12 @@
 <hr>
 <a href="index.html">Tutorial HOME</a> |
+<a href="intro.html">Intro</a> |
 <a href="demo.html">Demo LOCATION</a> |
 <a href="geom_storage.html">Geometry management</a> |
 <a href="attrib_storage.html">Attribute management</a> |
-<a href="examples.html">Usage Examples</a> |
+<a href="examples.html">Usage Examples</a> | <br>
+<a href="troubleshooting.html">Troubleshooting</a> |
 <a href="links.html">Links</a>
 <hr>
Index: demo.html
RCS file: /grassrepository/web/grass51/tutorial/demo.html,v
retrieving revision 1.7
retrieving revision 1.8
diff -u -d -r1.7 -r1.8
--- demo.html	20 Feb 2003 16:42:14 -0000	1.7
+++ demo.html	28 Feb 2003 20:00:04 -0000	1.8
@@ -19,10 +19,12 @@
 <hr>
 <hr>
Index: ex_basic.html
RCS file: /grassrepository/web/grass51/tutorial/ex_basic.html,v
retrieving revision 1.3
retrieving revision 1.4
diff -u -d -r1.3 -r1.4
--- ex_basic.html	20 Feb 2003 16:42:14 -0000	1.3
+++ ex_basic.html	28 Feb 2003 20:00:04 -0000	1.4
@@ -19,10 +19,12 @@
 <hr>
 <hr>
Index: ex_complex.html
RCS file: /grassrepository/web/grass51/tutorial/ex_complex.html,v
--- ex_complex.html	20 Feb 2003 16:42:14 -0000	1.3
+++ ex_complex.html	28 Feb 2003 20:00:04 -0000	1.4
@@ -19,10 +19,12 @@
 <hr>
 <hr>
Index: examples.html
RCS file: /grassrepository/web/grass51/tutorial/examples.html,v
retrieving revision 1.20
retrieving revision 1.21
diff -u -d -r1.20 -r1.21
--- examples.html	27 Feb 2003 21:52:58 -0000	1.20
+++ examples.html	28 Feb 2003 20:00:04 -0000	1.21
@@ -19,10 +19,12 @@
 <hr>
 <hr>
Index: geom_storage.html
RCS file: /grassrepository/web/grass51/tutorial/geom_storage.html,v
retrieving revision 1.11
retrieving revision 1.12
diff -u -d -r1.11 -r1.12
--- geom_storage.html	20 Feb 2003 16:42:14 -0000	1.11
+++ geom_storage.html	28 Feb 2003 20:00:04 -0000	1.12
@@ -19,10 +19,12 @@
 <hr>
 <hr>
@@ -40,6 +42,8 @@
 <hr>
 <a name="toc"></a>
 <ol>
+<li><a href="#intro">Introduction</a>
+<li><a href="#default">Managing the default settings</a>
 <li><a href="#native">Geometry stored in native format</a>
 <li><a href="#SHAPE">Geometry stored in SHAPE file: Registration of a map in
 SHAPE format</a>
@@ -52,6 +56,52 @@
 To get debug information, set variable (set to 0 for debug silence) to 1..5:<div class="code"><pre>
 export GRASS_DEBUG_LEVEL=5
 </div></pre>
+<p><table width="100%" cellpadding="3" border="0">
+<tr><td align="left" bgcolor="#B0F0B0"><font color="#00000"><big><b>
+<a name="intro"></a>
+Introduction
+<DIV ALIGN=right><a href="#toc">[UP]</a></DIV>
+</b></big></font></td></tr></table>
+The vector geometry management was completely changed in GRASS 5.1 to
+achieve more flexibility, support for 3D vectors etc. At time of this
+writing following options for vector geometry storage are available:
+<ul>
+<li>native 5.1 vector format (default)
+<li>PostGRASS (PostgreSQL/PostGIS based in a database)
+<li>SHAPE format
+<li>OGR supported formats (ArcInfo, GML etc)
+</ul>
+The 5.0 sites format has been migrated into the new vector format.
+Vector networking is implemented.
+<a name="default"></a>
+Managing the default settings
+Per default vector map geometry is stored locally in native 5.1 format.
+This default definition can be modified with:
+<div class="code"><pre>
+v.format
+</div></pre>
+<P>
+Possible settings are for "Output Format":
+<ul>
+<li>native: (nothing else to be selected/filled)
+<li>PostGIS: <br>
+         database='host=pgserver.itc.it,dbname=grass51test,user=name'
+<li>SHAPE: This can be used to register a SHAPE into a MAPSET<br>
+   Select SHAPE file with 'Browse'
+</ul>
Index: index.html
RCS file: /grassrepository/web/grass51/tutorial/index.html,v
--- index.html	17 Feb 2003 15:49:07 -0000	1.14
+++ index.html	28 Feb 2003 20:00:04 -0000	1.15
@@ -18,7 +18,7 @@
 <A HREF="../index.html">
 <DEFANGED_IMG src="../../images/grass.smlogo.gif" alt="HOME" border="0" align=middle></A>
 </td><td><H1>
-GRASS 5.1 (draft) Tutorial
+GRASS 5.1 Tutorial
 </H1></td></tr></table>
 <!-- END OF HEADER -->
 <p>
Index: intro.html
RCS file: /grassrepository/web/grass51/tutorial/intro.html,v
diff -u -d -r1.2 -r1.3
--- intro.html	20 Feb 2003 16:42:14 -0000	1.2
+++ intro.html	28 Feb 2003 20:00:04 -0000	1.3
@@ -19,6 +19,7 @@
 <hr>
@@ -45,15 +46,16 @@
 Per default all GRASS 5.1 vectors are stored in native 5.1 format within the
 directory $GISDBASE/$LOCATION_NAME/$MAPSET/vector/$MAP/. All map related
 data such as geometry data, spatial index, DB-connection (dbln file) info
-etc. are stored in this directory. Geometry can be also read from SHAPE files
-directly, read and written to PostGRASS (using PostGIS) and in future
-through OGR. See <i>Geometry management</i> below for details. <p>
+etc. are stored in this directory. Geometry can be also read from SHAPE
+files directly, read and written to PostGRASS (using PostGIS) and in future
+through OGR. <b>The default settings for geometry storage can be modified with
+'v.format'.</b>  See <i>Geometry management</i> below for details. <p>
 <b>Default settings for vector attributes</b><p>
 Per default all GRASS 5.1 vector attributes are stored in a DBF table within
-the directory $GISDBASE/$LOCATION_NAME/$MAPSET/dbf. The default settings
-for attribute storage can be modified with 'v.database'.
+the directory $GISDBASE/$LOCATION_NAME/$MAPSET/dbf. <b>The default settings
+for attribute storage can be modified with 'v.database'.</b>
 If required, a map can be linked to a certain table with 'v.db.connect'.
 See <i>Attribute management</i> below for details. <P>
Index: links.html
RCS file: /grassrepository/web/grass51/tutorial/links.html,v
--- links.html	17 Feb 2003 15:49:07 -0000	1.3
+++ links.html	28 Feb 2003 20:00:04 -0000	1.4
@@ -19,10 +19,12 @@
 <hr>
 <hr>
Index: techdocs.html
RCS file: /grassrepository/web/grass51/tutorial/techdocs.html,v
--- techdocs.html	20 Feb 2003 16:42:14 -0000	1.2
+++ techdocs.html	28 Feb 2003 20:00:04 -0000	1.3
@@ -19,10 +19,12 @@
 <hr>
 <hr>
Index: troubleshooting.html
RCS file: /grassrepository/web/grass51/tutorial/troubleshooting.html,v
--- troubleshooting.html	17 Feb 2003 15:49:07 -0000	1.3
+++ troubleshooting.html	28 Feb 2003 20:00:04 -0000	1.4
@@ -19,6 +19,7 @@
 <hr>
More information about the grass-web mailing list
