[GRASSweb-list]markus: web/grass51/tutorial attrib_storage.html,1.3,1.4
grass at intevation.de
Wed Jan 15 12:04:21 EST 2003
Author: markus
Update of /grassrepository/web/grass51/tutorial
In directory doto:/tmp/cvs-serv8466
Modified Files:
attrib_storage.html
Log Message:
PostgreSQL enhanced
Index: attrib_storage.html
RCS file: /grassrepository/web/grass51/tutorial/attrib_storage.html,v
retrieving revision 1.3
retrieving revision 1.4
diff -u -d -r1.3 -r1.4
--- attrib_storage.html 2 Jan 2003 16:35:55 -0000 1.3
+++ attrib_storage.html 15 Jan 2003 17:04:19 -0000 1.4
@@ -336,13 +336,15 @@
markveggy.shp 1 markveggy VEGCNP_ID grass51test pg
</div></pre>
-Connect GRASS 5.1 to the table:
+Connect GRASS 5.1 to the table (on machine 'pgserver' runs PostgreSQL):
<div class="code"><pre>
-db.connect driver=pg database=grass51test
+db.connect driver=pg database="host=pgserver,dbname=grass51test,user=neteler"
db.tables -p
db.describe -c markveggy
</div></pre>
+If a password is required, a dialog will ask you (or you supply
+'password=secretword').
This should print name and columns of the table 'markveggy' which is stored
as PostgreSQL table.
@@ -368,7 +370,7 @@
Example: Connection of SHAPE file with attributes in mySQL database table
directly connected to GRASS 5.1.<p>
-TODO.
+TODO (will be similar to PostgreSQL).
<p><table width="100%" cellpadding="3" border="0">
<tr><td align="left" bgcolor="#B0F0B0"><font color="#00000"><big><b>
More information about the grass-web
