[GRASSweb-list]markus: web/grass51/tutorial attrib_storage.html,1.5,1.6 examples.html,1.4,1.5 geom_storage.html,1.3,1.4
grass at intevation.de
Tue Jan 21 12:39:43 EST 2003
Author: markus
Update of /grassrepository/web/grass51/tutorial
In directory doto:/tmp/cvs-serv11964
Modified Files:
attrib_storage.html examples.html geom_storage.html
Log Message:
PostGIS/PostGRASS support added, some style cleanup
Index: attrib_storage.html
RCS file: /grassrepository/web/grass51/tutorial/attrib_storage.html,v
retrieving revision 1.5
retrieving revision 1.6
diff -u -d -r1.5 -r1.6
--- attrib_storage.html 15 Jan 2003 18:01:36 -0000 1.5
+++ attrib_storage.html 21 Jan 2003 17:39:41 -0000 1.6
@@ -35,7 +35,32 @@
send us further examples and/or code bugfixes/enhancements.</i>
<P>
-<h2>Introduction</h2>
+<hr>
+<a name="toc"></a>
+<ol>
+<li><a href="#intro">Introduction</a>
+<li><a href="#DBF">Attributes stored in DBF table</a>
+<li><a href="#ODBC">Attributes stored in external database (PostgreSQL)
+ connected through ODBC</a>
+<li><a href="#PostgreSQL">Attributes stored in external database (PostgreSQL)
+ directly connected</a>
+<li><a href="#mySQL">Attributes stored in external database (mySQL)
+<li><a href="#StarOffice">Changing table column types with StarOffice</a>
+<li><a href="#OpenOffice">Changing table column types with OpenOffice</a>
+</ol>
+To get debug information, set variable (set to 0 for debug silence) to 1..5:<div class="code"><pre>
+export GRASS_DEBUG_LEVEL=5
+</div></pre>
+<p><table width="100%" cellpadding="3" border="0">
+<tr><td align="left" bgcolor="#B0F0B0"><font color="#00000"><big><b>
+<a name="intro"></a>
+Introduction
+<DIV ALIGN=right><a href="#toc">[UP]</a></DIV>
+</b></big></font></td></tr></table>
The attribute management was completely changed in GRASS 5.1 to achieve
multi-attribute capabilities managed within external databases. The former
dig_cats/ files are not used any more and all vector attributes are stored
@@ -91,37 +116,17 @@
database and driver names. Note that $MAPSET is not current mapset but
mapset of the map the rule is defined for.
-<hr>
-<ol>
-<li><a href="#DBF">Attributes stored in DBF table</a>
-<li><a href="#ODBC">Attributes stored in external database (PostgreSQL)
- connected through ODBC</a>
-<li><a href="#PostgreSQL">Attributes stored in external database (PostgreSQL)
- directly connected</a>
-<li><a href="#mySQL">Attributes stored in external database (mySQL)
-<li><a href="#StarOffice">Changing table column types with StarOffice</a>
-<li><a href="#OpenOffice">Changing table column types with OpenOffice</a>
-</ol>
-To get debug information, set variable (set to 0 for debug silence) to 1..5:<div class="code"><pre>
-export GRASS_DEBUG_LEVEL=5
-</div></pre>
<a name="DBF"></a>
Attributes stored in DBF file
-Example: Connection of SHAPE file with attributes in DBF file.<p>
+Example: Connection of SHAPE file with attributes in DBF file which was
+registered with 'v.shape.register' (see <a href=geom_storage.html#SHAPE>here</a>).
-An entry in the GRASS 5.1 'DB' file such as:
-<div class="code"><pre>
-markveggy.shp 1 markveggy VEGCNP_ID /ssi0/ssi/neteler/grassdata/botswanaLL/shp dbf
-</div></pre>
-is required.
<p>
You can check the connection of a vector map to a table:
@@ -145,6 +150,7 @@
<a name="ODBC"></a>
Attributes stored in external database (PostgreSQL) connected
through ODBC
Possible communication between GRASS 5.1 and PostgreSQL database for
@@ -260,28 +266,14 @@
createdb -h rastrel grass51test
</div></pre>
-<li>Now store the table into PostgreSQL (you may use pg.in.dbf from 5.0 or other
-tools).
-<li>
-Now run the 'db.connect' command:
+<li>Now store the table 'markveggy.dbf' into PostgreSQL:
db.connect driver=odbc database=grass51test
+db.copy from_driver=dbf from_database=./ from_table=markveggy \
+ to_driver=pg to_database="host=pgserver,dbname=grass51test" \
+ to_table=markveggy
</div></pre>
-<li>Next we dump the DBF file into PostgreSQL (NOTE: unless we don't have a
- 'db.copy' command, we may 'pg.in.dbf' from GRASS 5.0 or
- the external 'pg2xbase' software):
-#go to directory, where registered SHAPE/DBF files are:
-cd `g.gisenv GISDBASE`
-cd `g.gisenv LOCATION_NAME`
-cd shp
-pg.in.dbf in=markveggy.dbf dumpmode=normal
-</div></pre>
<li> Next add an entry in the GRASS 5.1 'DB' file:
# map field table ID database DBMIdriver
@@ -317,6 +309,7 @@
<a name="PostgreSQL"></a>
Attributes stored in PostgreSQL database table
directly connected
Example: Connection of SHAPE file with attributes in PostgreSQL database table
@@ -329,8 +322,13 @@
</div></pre>
-Now store the table into PostgreSQL (you may use pg.in.dbf from 5.0 or other
-tools).
+Now store the table 'markveggy.dbf' into PostgreSQL:
+<div class="code"><pre>
+db.connect driver=odbc database=grass51test
+ to_driver=pg to_database="host=pgserver,dbname=grass51test,user=neteler" \
+</div></pre>
<p>
Let's assume that PostgreSQL runs on machine 'pgserver'.
Add entry in the GRASS 5.1 'DB' file in the mapset directory:
@@ -371,6 +369,7 @@
<a name="mySQL"></a>
Attributes stored in mySQL database table
Example: Connection of SHAPE file with attributes in mySQL database table
@@ -382,6 +381,7 @@
<a name="StarOffice"></a>
Sometimes the ID field in a database table (e.g. .dbf) is of a wrong type.
@@ -415,6 +415,7 @@
<p><table width="100%" cellpadding="3" border="0"> <tr><td align="left"
bgcolor="#B0F0B0"><font color="#00000"><big><b> <a name="OpenOffice"></a>
@@ -444,7 +445,8 @@
Select the column and change the type to "Number" (alias Integer). Save the
table. Now GRASS 5.1 can use the ID column as it is of Integer type.
<br>
-PROBLEM: In OpenOffice 1.0.1 Number/Integer does not exist!!
+PROBLEM: In OpenOffice 1.0.1 Number/Integer does not exist!! So you better
+go with StarOffice.
<hr>
<b>Further Links:</b>
Index: examples.html
RCS file: /grassrepository/web/grass51/tutorial/examples.html,v
retrieving revision 1.4
diff -u -d -r1.4 -r1.5
--- examples.html 17 Jan 2003 17:37:45 -0000 1.4
+++ examples.html 21 Jan 2003 17:39:41 -0000 1.5
@@ -360,7 +360,7 @@
db.copy from_driver=dbf from_database=./ from_table=census1990wet \
- to_driver=pg to_database=host=pgserver,dbname=grass51test \
to_table=census1990wetB
</div></pre>
Index: geom_storage.html
RCS file: /grassrepository/web/grass51/tutorial/geom_storage.html,v
retrieving revision 1.3
diff -u -d -r1.3 -r1.4
--- geom_storage.html 9 Jan 2003 17:58:05 -0000 1.3
+++ geom_storage.html 21 Jan 2003 17:39:41 -0000 1.4
@@ -35,7 +35,27 @@
<P>
+<hr>
+<a name="toc"></a>
+<ol>
+<li><a href="#native">Geometry stored in native format</a>
+<li><a href="#SHAPE">Geometry stored in SHAPE file: Registration of a map in
+SHAPE format</a>
+<li><a href="#PostGRASS">Geometry stored in external database (PostGRASS)
+using PostGIS</a>
+</ol>
+</div></pre>
+<a name="native"></a>
+Introduction
In GIS the vector data model is used for geographic phenomena which may be
represented by geometric entities (primitives) like points, lines, and
areas. In GRASS 5.1 the vector data model includes the description of
@@ -69,24 +89,11 @@
See some vector API details <a href="http://freegis.org/cgi-bin/viewcvs.cgi/~checkout~/grass51/doc/vector/vector.html">here</a>.
-<hr>
-<ol>
-<li><a href="#native">Geometry stored in native format</a>
-<li><a href="#SHAPE">Geometry stored in SHAPE file: Registration of a map in
-SHAPE format</a>
-<li><a href="#PostGRASS">Geometry stored in external database (PostGRASS)
-using PostGIS</a>
-</ol>
-</div></pre>
Per default the vector geometry is stored in the GRASS 5.1 location
@@ -99,25 +106,17 @@
-<a name="ODBC"></a>
-Geometry stored in SHAPE file: Registration of a map in SHAPE format
+<a name="SHAPE"></a>
+Geometry stored in SHAPE file: Registering a map in SHAPE format
Direct SHAPE file support is implemented, i.e. maps in SHAPE format can be
-used directly in GRASS 5.1 without importing them.
+used directly in GRASS 5.1 without importing them. But you have to register
+the SHAPE file, it may be useful to copy them into the LOCATION:
-#register SHAPE files (this will copy them into the LOCATION):
v.shape.register markveggy.shp
- markveggy.shp is registered now.
- The SHAPE files (.shp, shx and .dbf) were copied to:
- /ssi0/ssi/neteler/grassdata/botswanaLL/shp
- Consider to run v.build:
- v.build markveggy.shp
-#build pseudo-topology for SHAPE
#get info about vector map:
v.info markveggy.shp
@@ -127,7 +126,7 @@
d.vect markveggy.shp
</div></pre>
-DBF table do not have to be registered in the DB file.
+For SHAPE format, DBF table do not have to be registered in the DB file.
Read also <a href="attrib_storage.html#DBF">Attributes stored in DBF table</a>.
@@ -141,17 +140,83 @@
<a name="PostGRASS"></a>
Geometry stored in PostGRASS database table using PostGIS
-Using PostGRASS which stores the vector geometry in a PostgreSQL/PostGIS
-database, multiple user write access to vector geometry becomes possible.
+Current PostGRASS limitations: It is not possible use PostGIS data imported
+by ogr2ogr in GRASS (OGR support is planned but not yet present).
+Data must be first imported into GRASS, then written to PostGIS.
+<br>
+<i>Future: Using PostGRASS which stores the vector geometry in a
+PostgreSQL/PostGIS database, multiple user write access to vector geometry
+will become possible. Then also updating of vector geometry stored in
+PostGRASS with v.digit will be possible.</i>
<P>
-TODO.
+In this example we want to put the vector map 'census1990wet.shp' (a SHAPE
+file registed into GRASS) into database 'botswanaUTM34' on server 'pgserver'
+as user 'postgres'. First we create a PostGIS database (the example needs
+the file postgis.sql in the current directory):
+postgisdb -c botswanaUTM34 -h pgserver.itc.it -U postgres -G ./
+</div></pre>
+Next we have to create a 'frmt' file which defines the PostGRASS connection
+and a 'head' file which defines the basic vector names:
+cd $HOME/grassdata/botswanaUTM34/PERMANENT/vector
+mkdir pgmap
+cd pgmap
+</div></pre>
+Here generate the ASCII file 'frmt':
+FORMAT:postgis
+HOST:pgserver.itc.it
+DATABASE:botswanaUTM34
+USER:postgres
+GEOM_TABLE:pgmapg
+CAT_TABLE:pgmapc
+</div></pre>
+Next we need a 'head' file (you may re-use another 'head' file from another
+vector map):
+ORGANIZATION: GRASS Development Team
+DIGIT DATE: /9/Jan
+DIGIT NAME: neteler
+MAP NAME: pgmap
+MAP DATE: 2002
+MAP SCALE: 50000
+OTHER INFO: -
+ZONE: 0
+MAP THRESH: 0.500000
+</div></pre>
+Finally we import the map to PostGRASS:
+v.out.ascii input=census1990wet.shp out=pgmap
+v.in.ascii input=pgmap out=pgmap
+</div></pre>
+For the attributes storage in PostgreSQL, please <a
+href="attrib_storage.html#PostgreSQL">read on here</a> ('db.copy' will
+help).
<P>
-Hints for GRASS-PostGIS: see e.g. <a
+Further hints for GRASS/PostGRASS/PostGIS: see e.g. <a
href="http://grass.itc.it/pipermail/grassuser/2002-November/015822.html">this
thread</a>.
+<hr>
+<b>Further Links:</b>
+<ul>
+<li><a href=http://postgis.refractions.net/docs/>PostGIS manual</a><br>
+</ul>
<!-- FOOTER -->
<p>
More information about the grass-web
