[GRASSweb-list]markus: web/grass51/tutorial links.html,NONE,1.1 attrib_storage.html,1.8,1.9 demo.html,1.3,1.4 examples.html,1.7,1.8 geom_storage.html,1.6,1.7
grass at intevation.de
Fri Jan 24 09:27:20 EST 2003
Author: markus
Update of /grassrepository/web/grass51/tutorial
In directory doto:/tmp/cvs-serv2904/tutorial
Modified Files:
attrib_storage.html demo.html examples.html geom_storage.html
Added Files:
links.html
Log Message:
updated links to GRASS 5.1 programmer's manuals
--- NEW FILE: links.html ---
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<DEFANGED_meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
<DEFANGED_meta name="Author" content="Markus Neteler">
<DEFANGED_link rel="stylesheet" type="text/css" href="../../sitestyle.css">
<title>GRASS 5.1 Usage examples</title>
</head>
<body>
<!-- HEADER -->
<table width=100%><tr><td width=80>
<A HREF="index.html">
<DEFANGED_IMG src="../../images/grass.smlogo.gif" alt="HOME" border="0" align=middle></A>
</td><td><H1>
GRASS 5.1 Usage Examples
</H1></td></tr></table>
<!-- END OF HEADER -->
<hr>
<a href="index.html">Tutorial HOME</a> |
<a href="demo.html">Demo LOCATION</a> |
<a href="geom_storage.html">Geometry management</a> |
<a href="attrib_storage.html">Attribute management</a> |
<a href="examples.html">Usage Examples</a> |
<a href="links.html">Links</a>
<hr>
<b>Further Links:</b>
<ul>
<li>Vector attributes:
<ul>
<li><a href=http://www.redhat.com/docs/manuals/database/RHDB-2.1-Manual/sql/sqlreference.html>SQL
Guide and Reference</a> (Red Hat)
<li><a href=http://techdocs.postgresql.org/>PostgreSQL Technical Documentation</a>
<li><a href=http://www.ca.postgresql.org/users-lounge/docs/>PostgreSQL Documentation</a>
<li><a href=http://www.klaban.torun.pl/prog/pg2xbase/>pg2xbase</a>
(DBF <-> PostgreSQL)
<li><a href=http://mdbtools.sourceforge.net/>mdbtools</a> (converts
MS-ACCESS data to SQL, DBF etc.)<br>
<tt>gmdb dbfile.mdb</tt>
<li><a href=http://www.unixodbc.org/>unixODBC</a> to connect GRASS 5.1
to database servers such as PostgreSQL, Oracle etc.
</ul>
<P>
<li>Vector geometry:
<ul>
<li>Converter: <a href=http://postgis.refractions.net/download.php>PostGIS with shp2pgsql</a>:<br>
<tt>shp2pgsql -D lakespy2 lakespy2 test > lakespy2.sql</tt>
<li>Converter: <a href=http://e00pg.sourceforge.net/>e002pg</a> (E00 to PostGIS
filter)
<li>Converter: <a href=http://gdal.velocet.ca/projects/opengis/>ogrinfo and
ogr2ogr</a> (GIS vector format converter and
library, e.g. ArcInfo or SHAPE -> PostGIS)<br>
<tt>ogr2ogr -f "PostgreSQL" shapefile ??</tt>
<li><a href=http://gdal.velocet.ca/projects/opengis/ogrhtml/drv_pg.html>ogr2ogr -
PostgreSQL driver docs</a>
</ul>
</ul>
<!-- FOOTER -->
<p>
<hr>
<DIV ALIGN=right>© 2002 Markus Neteler<br>
<a href="mailto:weblist at grass.itc.it">Comments</a> about this page | <a href="../../faq/index.html">FAQ</a> | <a href="../../download.html">Download</a> | <a href="../../support.html">Support</a> | <a href="../../gdp/index.html">Docs</a> | <a href="../../grassdevel.html">Programming</a> | Back <a href=index.html>5.1 Tutorial Home</a><br>
<i>Last change:
$Date: 2003/01/24 14:27:18 $
</i></DIV>
</body>
</html>
Index: attrib_storage.html
RCS file: /grassrepository/web/grass51/tutorial/attrib_storage.html,v
retrieving revision 1.8
retrieving revision 1.9
diff -u -d -r1.8 -r1.9
--- attrib_storage.html 24 Jan 2003 10:36:58 -0000 1.8
+++ attrib_storage.html 24 Jan 2003 14:27:18 -0000 1.9
@@ -22,7 +22,8 @@
-<a href="examples.html">Usage Examples</a>
+<a href="examples.html">Usage Examples</a> |
+<a href="links.html">Links</a>
<hr>
<i><b>README:</b>
@@ -449,23 +450,8 @@
go with StarOffice.
<hr>
-<b>Further Links:</b>
-<ul>
-<li><a href=http://www.postgresql.org/>PostgreSQL</a> and
- <a href=http://techdocs.postgresql.org/>PostgreSQL Technical
- Documentation</a>
-<li><a href=http://www.ca.postgresql.org/users-lounge/docs/>PostgreSQL Documentation</a>
-<li><a href=http://gdal.velocet.ca/projects/opengis/ogrhtml/drv_pg.html>ogr2ogr -
- PostgreSQL</a>
-<li><a href=http://www.klaban.torun.pl/prog/pg2xbase/>pg2xbase</a>
- (DBF <-> PostgreSQL)
-<li><a href=http://mdbtools.sourceforge.net/>mdbtools</a> (converts
- MS-ACCESS data to SQL, DBF etc.)<br>
- <tt>gmdb dbfile.mdb</tt>
-<li><a href=http://www.unixodbc.org/>unixODBC</a> to connect GRASS 5.1
- to database servers such as PostgreSQL, Oracle etc.
-</ul>
+<P>
+Further <a href=links.html>Links</a> (related software, SQL reference etc).
<!-- FOOTER -->
<p>
Index: demo.html
RCS file: /grassrepository/web/grass51/tutorial/demo.html,v
retrieving revision 1.3
retrieving revision 1.4
diff -u -d -r1.3 -r1.4
--- demo.html 23 Jan 2003 15:42:49 -0000 1.3
+++ demo.html 24 Jan 2003 14:27:18 -0000 1.4
@@ -22,7 +22,8 @@
<hr>
<i><b>README:</b>
@@ -210,6 +211,10 @@
The other scripts stored in the LOCATION directory are internally used by
some demo scripts.
+<hr>
+<P>
<!-- FOOTER -->
<p>
Index: examples.html
RCS file: /grassrepository/web/grass51/tutorial/examples.html,v
retrieving revision 1.7
diff -u -d -r1.7 -r1.8
--- examples.html 24 Jan 2003 10:36:58 -0000 1.7
+++ examples.html 24 Jan 2003 14:27:18 -0000 1.8
@@ -22,7 +22,8 @@
<hr>
GRASS 5.1 is currently under development. It is neither complete (it still
@@ -572,29 +573,8 @@
and enjoy the map queries.
<hr>
-<ul>
-<li><a href=http://postgis.refractions.net/download.php>PostGIS with shp2pgsql</a>:<br>
- <tt>shp2pgsql -D lakespy2 lakespy2 test > lakespy2.sql</tt>
- Documentation</a>
-<li><a href=http://e00pg.sourceforge.net/>e002pg</a> (E00 to PostGIS
- filter)
-<li><a href=http://gdal.velocet.ca/projects/opengis/>ogrinfo and
- ogr2ogr</a> (GIS vector format converter and
- library, e.g. ArcInfo or SHAPE -> PostGIS)<br>
- <tt>ogr2ogr -f "PostgreSQL" shapefile ??</tt>
-</ul>
+<P>
<!-- FOOTER -->
<p>
Index: geom_storage.html
RCS file: /grassrepository/web/grass51/tutorial/geom_storage.html,v
retrieving revision 1.6
diff -u -d -r1.6 -r1.7
--- geom_storage.html 24 Jan 2003 10:36:58 -0000 1.6
+++ geom_storage.html 24 Jan 2003 14:27:18 -0000 1.7
@@ -22,7 +22,8 @@
<hr>
<i><b>README:</b>
@@ -212,21 +213,8 @@
<hr>
-<ul>
-<li><a href=http://postgis.refractions.net/docs/>PostGIS manual</a><br>
-<li><a href=http://postgis.refractions.net/>PostGIS with shp2pgsql</a>:<br>
- PostgreSQL</a>
- filter)
-</ul>
+<P>
<!-- FOOTER -->
<p>
More information about the grass-web
