[GRASSweb-list]markus: web/grass5 index.html,1.23,1.24
grass at intevation.de grass at intevation.de
Tue Jan 28 09:58:34 EST 2003
Author: markus
Update of /grassrepository/web/grass5
In directory doto:/tmp/cvs-serv26244/grass5
Modified Files:
Log Message:
updated to 5.0.1
Index: index.html
RCS file: /grassrepository/web/grass5/index.html,v
retrieving revision 1.23
retrieving revision 1.24
diff -u -d -r1.23 -r1.24
--- index.html	27 Nov 2002 09:05:09 -0000	1.23
+++ index.html	28 Jan 2003 14:58:32 -0000	1.24
@@ -25,19 +25,20 @@
 <a name="general"></a>
 <h2>General information</h2>
 <b>Current version:</b>
-GRASS 5.0.0 (released 5 September 2002)
+GRASS 5.0.1 (released 28 January 2003)
 <p>
+GRASS 5.0.1 is a (minor) bugfix release only.<p>
 <a href=../announces/press_release500.html>Press Release 5. September
 2002</a>: First Stable Release - GRASS 5 Free Geographic Information System
 <p>
-What's new in <b>current release of GRASS 5.0.0?</b>
+<h2>What's new in <b>current release of GRASS 5.0.x?</h2>
 <a href="source/NEWS.html">Read on the detailed NEWS list</a>.
 For details please read the detailed changes <A HREF="source/ChangeLog">HISTORY</a>.
-<h2>What's new in GRASS 5.0.0 compared to 4.x?</h2>
+<h2>What's new in GRASS 5.0.x compared to 4.x?</h2>
-GRASS 5.0.0 represents the first major change in GRASS functionality in
+GRASS 5.0.x represents the first major change in GRASS functionality in
 several years, with the most notable change being support for <b>floating
 point and null values</b>. GRASS also now has an improved graphical user
 interface based on Tcl/Tk. Additionally a new multiple attributes/multiple
@@ -60,9 +61,9 @@
 <a href=../announces/announce_lzw_removal.html>See also press release on GRASS raster compression changes</a>.
 <p>
-<h2>How stable is GRASS 5.0.0?</h2>
+<h2>How stable is GRASS 5.0.x?</h2>
-GRASS 5.0.0 has been tested on Linux, SUN, WindowsNT/2000/XP and Silicon
+GRASS 5.0.x has been tested on Linux, SUN, WindowsNT/2000/XP and Silicon
 Graphics Irix systems. Many people use it for daily production. HOWEVER,
 there are likely still some <a href=http://intevation.de/rt/webrt?q_queue=grass>bugs</a> to be worked
 out.
@@ -83,7 +84,7 @@
 <li> You are kindly requested to send your comments about GRASS 5 functionality
   (recent version).
 <li>List of <a  href="http://intevation.de/rt/webrt?q_queue=grass">known bugs
- in this GRASS 5.0.0 version</A>. Your help to fix these bugs is highly appreciated. If you find
+ in this GRASS 5.0.x version</A>. Your help to fix these bugs is highly appreciated. If you find
  a bug, please check the list if it is already known. If not, you are kindly
  requested to report the bug(s) to use our new <a href="../bugtracking/bugreport.html">bug report form</a>
 </menu>
@@ -102,6 +103,8 @@
 However, this only helps if you want to run several modules in parallel.
 Individual modules will be run serially on one CPU. So this is more
 load-balancing than a real cluster. It should be quite easy to set up.
+<li><a href=http://openmosix.sourceforge.net/>openMOSIX</a>: There is also
+openMOSIX.
 <li><a
 href=http://www.beowulf.org>Beowulf Cluster</a>: Requires GRASS
 modifications not done yet.
@@ -127,7 +130,7 @@
 <a name="download"></a>
 <h2>Download</h2>
-<b>Ok, ok.  How can I get current GRASS 5.0.0 release?</b><p>
+<b>Ok, ok.  How can I get current GRASS 5.0.x release?</b><p>
 First, <a href="../downloadform.html">fill out the download form.</a><p>
 Second, go to the <b><a href="../download.html">download page</a></b> and start downloading!<p>
 <p>
More information about the grass-web mailing list
