[GRASSweb-list]markus: web related_projects.html,1.18,1.19
grass at intevation.de
Wed Jan 29 04:15:07 EST 2003
Author: markus
Update of /grassrepository/web
In directory doto:/tmp/cvs-serv16144
Modified Files:
Log Message:
added cs2cs hint
Index: related_projects.html
RCS file: /grassrepository/web/related_projects.html,v
retrieving revision 1.18
retrieving revision 1.19
diff -u -d -r1.18 -r1.19
--- related_projects.html 27 Nov 2002 09:05:09 -0000 1.18
+++ related_projects.html 29 Jan 2003 09:15:05 -0000 1.19
@@ -22,7 +22,9 @@
<h2>Libraries</h2>
<ul>
-<li><a href=http://www.remotesensing.org/proj/>PROJ 4</a>: Projection/datum support library
+<li><a href=http://www.remotesensing.org/proj/>PROJ 4</a>: Projection/datum support
+ library. It also provides the 'cs2cs' software which reprojects x,y [,z]
+ coordinate lists including datum transformation.
<li><a href=http://gdal.velocet.ca/projects/grass/>libgrass</a>: Standalone GRASS
5 I/O Library to directly read/write GRASS Databases.
<br>The latest libgrass source is also available by anonymous CVS:
More information about the grass-web
