[GRASSweb-list]markus: web/grass51/binary/linux README.html,1.3,1.4
    grass at intevation.de
    Fri Jan 31 09:42:45 EST 2003
Author: markus
Update of /grassrepository/web/grass51/binary/linux
In directory doto:/tmp/cvs-serv20263
Modified Files:
	README.html
Log Message:
update
Index: README.html
RCS file: /grassrepository/web/grass51/binary/linux/README.html,v
retrieving revision 1.3
retrieving revision 1.4
diff -u -d -r1.3 -r1.4
--- README.html	24 Jan 2003 14:33:31 -0000	1.3
+++ README.html	31 Jan 2003 14:42:43 -0000	1.4
@@ -4,21 +4,21 @@
 This directory contains the Linux (x86/Intel) binary code for
 GRASS 5.1 EXPERIMENTAL in gzipped tar format.
-<b>Note that this binary version may be significantly older than
-   the latest code in CVS</b>. We recommend to compile from CVS.
+<b>Note that this binary version may not work.
+   Use at your own risk.</b>
 Installation:
 1. get the file
-     grass51-MMDDYY-arch-bin.tar.gz
+     grass51-DD-MM-YYYY-arch-bin.tar.gz
 2. get the installation script
-     grass51-MMDDYY-arch-install.sh
+     grass51-DD-MM-YYYY-arch-install.sh
 Note: this code is highly experimental and may be malfunctioning.<br>
 For installation, run the install script with --help option:
-     grass51-MMDDYY-arch-install.sh --help
+     grass51-DD-MM-YYYY-arch-install.sh --help
 <hr>
 Please help us and report bugs.
More information about the grass-web
