[GRASSweb-list]markus: web/grass5/binary/linux mandrake.html,1.3,1.4
grass at intevation.de grass at intevation.de
Tue Jul 22 05:22:32 EDT 2003
Author: markus
Update of /grassrepository/web/grass5/binary/linux
In directory doto:/tmp/cvs-serv25685
Modified Files:
	mandrake.html
Log Message:
updated
Index: mandrake.html
RCS file: /grassrepository/web/grass5/binary/linux/mandrake.html,v
retrieving revision 1.3
retrieving revision 1.4
diff -u -d -r1.3 -r1.4
--- mandrake.html	16 Apr 2003 15:29:32 -0000	1.3
+++ mandrake.html	22 Jul 2003 09:22:30 -0000	1.4
@@ -1,13 +1,44 @@
 <html><pre>
-GRASS 5 for Mandrake:
+<h2>GRASS 5 for Mandrake Linux</h2>
+Mandrake Linux is a large distribution, and MandrakeSoft cannot officially
+support all packages that may be useful, thus the "contributed" rpms, which
+are synchronised with each main release, many of which are maintained by
+non-Mandrakesoft contributors.
+GRASS (5.0.0 is in Mandrake 9.1 contribs) is such a package, and also relies
+on a number of such packages.
+Possible ways to get GRASS for Mandrake Linux:
+1) First you can search <a href=http://rpms.mandrakeclub.com/search.php?query=grass>MandrakeClub for RPMs</a>.
+2) The GRASS packages are also compiled against the some libraries,
+   and so will also require packages from contrib.
+   To setup your Mandrake Linux system to install packages from contrib,
+   either:
+   a) Buy a PowerPack or ProSuite version (both ship with grass-5.0.0)
+   b) Add a contrib urpmi medium to the list of sources on your computer,
+      which can be easily done, either by running
+       urpmi.setup ('urpmi urpmi.setup; urpmi.setup') or by visiting
+       <a href=http://plf.zarb.org/~nanardon>http://plf.zarb.org/~nanardon</a>
+   The page <a href=http://plf.zarb.org/faq.html>http://plf.zarb.org/faq.html</a> may also explain some more of the
+   issues.
+   NOTE: With a few urpmi media setups, you will <b>never</b> need to search for packages
+   (ie at rpmfind.net again (unless you are looking for newer versions ...).
+3) An alternative is:
 You can install GRASS 5 via 'urpmi' from my site:
 <a href=http://ranger.dnsalias.com/mandrake>http://ranger.dnsalias.com/mandrake</a>
 Feedback welcome.
 |----------------Registered Linux User #182071-----------------|
 Buchan Milne                Mechanical Engineer, Network Manager
 Cellphone * Work            +27 82 472 2231 * +27 21 8828820x202
More information about the grass-web mailing list
