[GRASSweb-list]markus: web/nviz index.html,1.4,1.5
grass at intevation.de
Fri Mar 7 03:21:40 EST 2003
Author: markus
Update of /grassrepository/web/nviz
In directory doto:/tmp/cvs-serv5712
Modified Files:
Log Message:
short note added
Index: index.html
RCS file: /grassrepository/web/nviz/index.html,v
retrieving revision 1.4
retrieving revision 1.5
diff -u -d -r1.4 -r1.5
--- index.html 27 Nov 2002 09:05:10 -0000 1.4
+++ index.html 7 Mar 2003 08:21:38 -0000 1.5
@@ -14,19 +14,30 @@
<center><a href="../images/nviz22_big.jpg"><DEFANGED_IMG src="../images/nviz22.jpg"></a></center>
+NVIZ is a GRASS module which allows users to realistically render multiple
+surfaces in a 3D space, optionally using thematic coloring, draping GRASS
+vector files over the surfaces, and displaying GRASS site files either
+draped on the surfaces or as 3D point locations.
+The NVIZ code is part of the standard GRASS source code
+(src.contrib/GMSL/NVIZ2.2/).
<h3>
Related links:</h3>
-<menu>
+<ul>
<li>
-<a href="../gdp/nviz/index.html">NVIZ
-Tutorial</a></li>
+<a href="../gdp/nviz/index.html">NVIZ Tutorial</a></li>
<li>
<a href="../nvizlist.html">NVIZ
visualization tool Mailing List</a> For the latest info and development
issues on using NVIZ and GRASS
-<hr width=70%></li>
+</ul>
+<hr width=70%>
+<ul>
<li>
NVIZ <a href="http://freegis.org/cgi-bin/viewcvs.cgi/~checkout~/grass/src.contrib/GMSL/NVIZ2.2/BUGS_TODO">TODO
@@ -43,13 +54,14 @@
the mpeg_encode software: <a href="../faq/mpegparam.txt">mpegparam.txt</a>.
Adjust the file name and the number of images you want to convert. Finally
use <a href="ftp://mm-ftp.cs.berkeley.edu/pub/multimedia/mpeg/play/">mpeg_play</a>
-to play the film.</menu>
+to play the film.
+</ul>
<hr>
<center>
-<h2>
-Examples done with NVIZ 3D
-tool</h2></center>
+<h2> Examples done with NVIZ 3D tool</h2></center>
<dl>
<center>
More information about the grass-web
