[GRASSweb-list]paul: web wingrass.html,1.13,1.14
grass at intevation.de
Tue Oct 7 12:21:30 EDT 2003
Author: paul
Update of /grassrepository/web
In directory doto:/tmp/cvs-serv29990
Modified Files:
wingrass.html
Log Message:
Make hint about NTFS more prominent
Index: wingrass.html
RCS file: /grassrepository/web/wingrass.html,v
retrieving revision 1.13
retrieving revision 1.14
diff -u -d -r1.13 -r1.14
--- wingrass.html 18 Dec 2002 08:12:29 -0000 1.13
+++ wingrass.html 7 Oct 2003 16:21:28 -0000 1.14
@@ -82,7 +82,9 @@
<b>NOTE 1: GRASS does not cope (yet) with spaces in directory names. Take this
into account when installing GRASS on MS-Windows.</b><br>
<b>NOTE 2: When selecting the root install directory, make sure that
-the "Default Text File Type" is set to Unix.</b>
+the "Default Text File Type" is set to Unix.</b><br>
+<b>NOTE 3: You must install/compile GRASS on an NTFS partition
+(FAT will not work!)</b>
<p>
<b>Download pre-compiled winGRASS
More information about the grass-web
