[GRASSweb-list]my messages still rejected
Markus Neteler
neteler at itc.it
Fri Oct 17 08:29:07 EDT 2003
On Fri, Oct 17, 2003 at 03:24:03PM +0300, temiz wrote:
> Markus Neteler wrote:
> >On Fri, Oct 17, 2003 at 01:25:50PM +0300, temiz wrote:
> >>hello
> >>my messages are still rejected in spite of the fact that I have
> >>subscribed to user list (grass at baylor.edu) recently.
> >The trick is to post to the correct address:
> >grasslist at baylor.edu
> >The address grass at baylor.edu is something else.
> thank you
> But I sent a test message to grasslist at baylor.edu.
> it is still rejected.
> Where did I do wrong ?
Sorry, I don't know. The Baylor people will have to check that.
> But only messages I can not get are from grass user list .
> On the other hand I get message from statgrass which
> I subscribed at the same time with grass-user.
'statgrass' and all other lists are hosted here in Italy while
grasslist at baylor.edu is hosted in USA.
Markus
> here is the respond message to my test message to grasslist at baylor.edu :
> Dear temiz at deprem.gov.tr:
> Your recent message to the GRASSLIST list has been
> rejected for the following reason:
> Only list subscribers may send messages to this list.
> If you need assistance, please contact the list owner at
> GRASSLIST-request at baylor.edu
> The text of your message follows:
> Received: from waylon.baylor.edu (waylon.baylor.edu [129.62.3.228])
> by ccis01.baylor.edu (8.9.3p2/8.9.1) with ESMTP id HAA1090550
> for <GRASSLIST at listproc.baylor.edu>; Fri, 17 Oct 2003 07:01:29 -0500 (CDT)
> Received: from messageinspecto.baylor.edu ([129.62.8.32]) by waylon.baylor.edu with Microsoft SMTPSVC(5.0.2195.5329);
> Received: from willie.baylor.edu (willie.baylor.edu [129.62.8.12])
> by messageinspecto.baylor.edu (Switch-2.2.8/Switch-2.2.4) with SMTP id V9HC114O00000C28
> for <grasslist at baylor.edu>; Fri, 17 Oct 2003 07:01:40 -0500
> Received: from posta.deprem.gov.tr ([194.27.223.8])
> by willie.baylor.edu (SAVSMTP 3.1.1.32) with SMTP id M2003101707010724621
> for <grasslist at baylor.edu>; Fri, 17 Oct 2003 07:01:18 -0500
> Received: (from root at localhost)
> by posta.deprem.gov.tr (8.12.6/8.12.6) id h9HC0oaU057009
> for grasslist at baylor.edu; Fri, 17 Oct 2003 15:00:51 +0300 (EEST)
> (envelope-from temiz at deprem.gov.tr)
> Received: from deprem.gov.tr (landslide.deprem.gov.tr [194.27.223.31])
> by posta.deprem.gov.tr (8.12.6/8.12.6) with ESMTP id h9HC0jx0056980
> for <grasslist at baylor.edu>; Fri, 17 Oct 2003 15:00:50 +0300 (EEST)
> Message-ID: <3F8FDA8C.10106 at deprem.gov.tr>
> Date: Fri, 17 Oct 2003 15:03:24 +0300
> From: temiz <temiz at deprem.gov.tr>
> User-Agent: Mozilla/5.0 (X11; U; Linux i686; en-US; rv:1.2.1) Gecko/20030225
> X-Accept-Language: en-us, en
> MIME-Version: 1.0
> To: grasslist at baylor.edu
> Subject: test
> Content-Type: text/plain; charset=us-ascii; format=flowed
> Content-Transfer-Encoding: 7bit
> X-scanner: scanned by Inflex 1.0.12.3 - (http://pldaniels.com/inflex/)
> X-ElronSig: bb5f06fb83f0b78eb83bdfb9fc36ad54
> X-OriginalArrivalTime: 17 Oct 2003 12:01:29.0804 (UTC) FILETIME=[6648E0C0:01C394A6]
> test
> Ahmet Temiz
> General Directory of Disaster Affairs
> Ankara TURKEY
> ______________________________________
> Inflex - installed on mailserver for domain @deprem.gov.tr
> Queries to: postmaster at deprem.gov.tr
> Ahmet Temiz
> Ankara TURKEY
> The views and opinions expressed in this e-mail message are the sender's own
> and do not necessarily represent the views and the opinions of Earthquake Research Dept.
> of General Directorate of Disaster Affairs.
> Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal olarak T.C.
> B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici nitelikte degildir.
Markus Neteler <neteler at itc.it> http://mpa.itc.it
ITC-irst, Istituto per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
More information about the grass-web
