[GRASSweb-list]markus: web grassdevel.html,1.39,1.40
grass at intevation.de grass at intevation.de
Fri Oct 31 03:30:37 EST 2003
Author: markus
Update of /grassrepository/web
In directory doto:/tmp/cvs-serv28749
Modified Files:
	grassdevel.html
Log Message:
link to debugging docs added
Index: grassdevel.html
RCS file: /grassrepository/web/grassdevel.html,v
retrieving revision 1.39
retrieving revision 1.40
diff -u -d -r1.39 -r1.40
--- grassdevel.html	4 Aug 2003 16:06:23 -0000	1.39
+++ grassdevel.html	31 Oct 2003 08:30:34 -0000	1.40
@@ -145,6 +145,9 @@
 href="searchgrass.html">developers mailing list archive</a> before asking
 developers - most questions have been already answered several
 times :-)
+<P>
+Debugging: hints are collected in <a href="http://freegis.org/cgi-bin/viewcvs.cgi/grass/documents/debugging.txt?rev=HEAD&content-type=text/vnd.viewcvs-markup">documents/debugging.txt</a> in
+the source code.
 <a name=prog></a>
 <h2>GRASS 5 Programmer's Manual</h2>
@@ -159,9 +162,9 @@
   <li> <a href=demos/r.example.tar.gz>r.example: example C code for GRASS 5
      raster programming</a>
 </ul>
-<li><b>GRASS 5.1:</b>
+<li><b>GRASS 5.7:</b>
 <ul>
-  <li>GRASS 5.1 Programmer's Manual <a href=grass51/manuals/>PDF and HTML</a>
+  <li>GRASS 5.7 Programmer's Manual <a href=grass51/manuals/>PDF and HTML</a>
 </ul>
   <li><b>GRASS 4.x JAVA interface</b> (code is included in src.garden/grass.java/)
 </ul>
More information about the grass-web mailing list
